swaybar installed torque question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-09-2011, 05:45 PM   #1 (permalink)
badaz907's Avatar
View badaz907's Photo Gallery
I installed a trd rear sway tonight, it calls for the bolts to be installed backwards, so the bolts get inserted from the top, why? secondly its calls for 184 ft lbs, i dont have a air gun, i used a 1/2 breaker bar and a 2 ft long gas pipe for leverage to tighten them do you think this is tight enough should I be concerned?
badaz907 is offline   Reply With Quote
Old 03-09-2011, 05:50 PM   #2 (permalink)
badaz907's Avatar
update
sorry 3/4" breaker bar
Old 03-09-2011, 07:19 PM   #3 (permalink)
Gameroom cash: $457387
View cabur's Photo Gallery
Depends on your physical size.
Rent a torque wrench for a few hours to do the job properly and for your peace of mind. You do not want that sway bar coming off on the highway.
LE, Smart Key, Limousine tint, Back-up sensor. M.I.C. 7" DVD.
cabur is offline   Reply With Quote
Old 03-09-2011, 07:22 PM   #4 (permalink)
TLeong13's Avatar
Gameroom cash: $354530
View TLeong13's Photo Gallery
If u hear a clunking noise when going over a speed bump or when ur car goes from an angle to a flat surface....then it became loose...my friend installed mine after 6 months i started hearing the clunking noise n found out was loose then retightened it
2009 Corolla S Magnetic Gray Auto
Limo Tints|K&n Typhoon Intake|Upgraded Premium Horn|Smoked Tails, Reflectors & fogs||HID Kit FOG & Heads 6000k|TRD Lowering Springs|TRD FSB|TRD RSB|Wicked flow muffler|Weathertech Vent Visors|Keyhole Plugs|Calvin vinyl
Future:
JDM front lip|Headers|17in rims
TLeong13 is offline   Reply With Quote
Old 03-10-2011, 04:19 AM   #5 (permalink)
10th Gen. Corolla S Owner
SaltySteve's Avatar
View SaltySteve's Photo Gallery
X2. I'm sure they specify 184 ft-lbs for a reason. I couldn't get at mine with a good angle for enough leverage on one side so I ended up propping the end of my torque wrench up and using my foot. Don't judge me . . . .
2010 Corolla S BSP
~ TRD Lowering Springs ~ TRD FSB ~ TRD RSB ~ Weapon-R I-Throttle Controller ~ Kenwood X994 ~ 35% 3M Tint ~ 3M Clear Bra ~
SaltySteve is offline   Reply With Quote
Old 03-10-2011, 09:24 AM   #6 (permalink)
Baskin' In The Glow
Faceless1's Avatar
Gameroom cash: $127809
View Faceless1's Photo Gallery
I also just install mine but I used air tools to retighten it. Didn't put the bolts on backwards tho. (Guess I should have read further ) Plus air gun wouldn't fit that way. Anything I should worry about down the road? It's on there pretty tight.
2009 Corolla S, Magnetic Gray, Debadged, 16" Alloys, 20% Tint, 10" Orion Sub, Eclipse Amp-600w, 5K HIDs, WR Intake, Blacked-out Tails and Reflectors, MagnaFlow 2.25" Catback, Red Interior LEDs, TRD suspension
Faceless1 is offline   Reply With Quote
Old 03-10-2011, 09:43 AM   #7 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521119
View LeanBurn's Photo Gallery
Canada
If the nut/bolts were tightened with the same amount of physical effort it took to get them off, you should be good to go. I suppose you could always check it a week down the road for peace of mind..
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 03-10-2011, 10:46 AM   #8 (permalink)
Sometimes. Not always. Reversing the nut-bolt is, should the nut fall off, the bolt will still keep the pieces together.
