Installed the passenger side last night, and I think I got a problem. I think I might of 'bent' or 'distorted' or something when I was tightening the spacer on the rear passnger. To me the wheel looks like it has camber, but my buddys' grandpa is convinced that its a different size spacer. It looks like the top of the wheel is going inward towards the car and the bottom is going out.
On the weekend, I'm gonna take off both rear spacers and check if they actually are the same or different sizes. If whatever is 'bent' what can I do?
My 2009 Super White Toyota Corolla Xrs
Click my Signature to check out my CarDomain Profile!
2009 Toyota Corolla S
TRD Front Strut Tower Brace, Injen Cold Air Intake, Borla Axle-Back Exhaust, Drag DR-12 17"
Coming soon: Springs, Sway bar, Brake lines, and decals http://www.cardomain.com/ride/3883430/1
Some quick questions - did these wheel spacers change the steering feel from the EPS? Does the car seem to track better or worse than before, on and off the highway?
Generally increase the wheel track will enhance steering, as it increases the leverage the tire has against the steering components, usually increasing that self-centering behavior. But I'm more curious on how the EPS deals with it, not sure if it will be confused or not. On my 2009 Matrix XRS - there are times where the steering seems a bit "off".
I would take the wheel off & make sure that the spacer is sitting flush against the hub. Also look for any issue with the hub centric ring. I had a ring get pinched & not sit flush which caused the wheel to sit at an angle & wobble while rolling down the road. After taking it off I discovered the issue & corrected it.
__________________ 89 Supercharged White MR2 5-speed / 09 Corolla S CSM 5-speed
Gonna check this weekend and compare the spacers side by side to see if its actually the same size. I highly doubt its different, measured it, but doesn't hurt to double check.
Originally Posted by tu_culo
And leave them off!!!! LOL
Originally Posted by Overkill_311
Dim - What springs are you sitting on again?
Originally Posted by dagone12
9th gen Tein H Techs...
This is the anwser
Dim... not gonna lie, the previous spacers looked much better : /
I like these, I like the tiny bit of poke
Originally Posted by ChancreScolex
Not sure how accurate this test would be but can you get one of those square angle tools and hold it against the ground/wheel?
We tried doing that, but I didn't buy it when my buddy's grandpa was showing me. I wanted something more accurate, but we didn't have a level on hand.
I didn't feel a difference at all. As long as you have the same offset if the front and/or rear your won't feel a difference.
If you just have the set on one side, your gonna drift right/left depending on which side you put it on.
Originally Posted by creslayer
i like how you roll
Originally Posted by thestone11
What are the measurement of the new spacers compare to your older ones?
25mm was my old setup, now I'm running 32mm. 1" to 1 1/4".
Thanks for the tip, I'll check for that on the weekend when I get a chance to look at it.
Would it have been possible that I have bent something in the assembly to make the wheel sit at a angle? Or most likely its the spacer?
