Access hole in firewall - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-24-2011, 05:28 PM   #1 (permalink)
markymark975
markymark975's Avatar
View markymark975's Photo Gallery
Planning to run some wires from the battery to a toggle switch inside the car. Has anyone had any experience in running wires thru an existing hole in the firewall? If so what is the best way?
I see where a bunch of wires are already run thru but can't get my hand in there to even see if there is room to push 3 wires thru cuz it looks so tight. By the way, it's for an led "Knight rider" scanner light that right now is just connected directly to the battery. I'll post a vid when I get a chance. Looks pretty nice!
markymark975 is offline   Reply With Quote
Old 03-24-2011, 05:31 PM   #2 (permalink)
HellaAverage
Jackss731's Avatar
Gameroom cash: $406100
View Jackss731's Photo Gallery
yes! theres a rubber grommet and theres a pre-existing hole...but it doesnt go all the way through the grommet so you gotta poke the wires through using a hanger or something.
search my DIY LED STRIP INSTALL nvm here ....
follow all the wires
in the middle of the picuture you can see that tiny red dot...thats my wire going through the pre-existing hole. it just has that wire wrap in it so its hard to see
this is from the inside
Jack
2010 Corolla S MGM
Thunder Low, OEMk Fogs, Blacked out emblems, Hella Horns, Eyelids, Blacked out wheels,
Jackss731 is offline   Reply With Quote
Old 03-24-2011, 05:48 PM   #3 (permalink)
markymark975
Thanks Jack...I'll have to go check that out. Hopefully it's bright and sunny tomorrow. Oh by the way, here is that vid I promised...not too clear..from camera phone.
Old 03-24-2011, 06:45 PM   #4 (permalink)
markymark975
Pretty tight trying to get my hand under there because of the FSB. Will try to run it from the inside out tomorrow.
Old 03-24-2011, 06:46 PM   #5 (permalink)
Gameroom cash: $282005
View Dragon-88's Photo Gallery
Run a coat hanger, thats what I did was pretty easy...
Dragon-88 is online now   Reply With Quote
Old 03-24-2011, 06:49 PM   #6 (permalink)
thestone11's Avatar
Gameroom cash: $366887
View thestone11's Photo Gallery
Canada
http://www.youtube.com/watch?v=f8mEbxCBg4s
If you add blue color to the light, I am sure you can scare alot of people by pretending you are an undercover cop...
1985 Corolla GTS (AE86)
2002 Mazda Protege 5 (Sold)
2009 Corolla S: http://www.cardomain.com/ride/3820536
thestone11 is offline   Reply With Quote
Old 03-24-2011, 10:16 PM   #7 (permalink)
HellaAverage
Jackss731's Avatar
yeah definitely a wire hanger helps out!!!!
Jack
2010 Corolla S MGM
The Following User Says Thank You to Jackss731 For This Useful Post:
markymark975 (03-25-2011)
Old 03-24-2011, 10:43 PM   #8 (permalink)
The random one
Gameroom cash: $121516
View MiniPacou's Photo Gallery
Originally Posted by Dragon-88
Whats the easiest way to pass the wire through the firewall?
I had a look at the picture above and looked in the engine bay and it seemed like a tight fit. Still at work so wont be able to do the lights until tonight.
Originally Posted by MiniPacou View Post
take a wire hanger and get a straight wire out of it, make sure there's no bumps/knots and poke it through the grommet's hole. take your electric wire on the back end of the hanger wire and tape it real tight with vinyl electrical tape, it'll go through.
Got HIR?
MiniPacou is offline   Reply With Quote
The Following User Says Thank You to MiniPacou For This Useful Post:
Old 03-26-2011, 04:46 PM   #9 (permalink)
markymark975
Wow after spending almost 2 hours going back and forth from the engine bay to under the dash, I almost gave up trying to find an access hole. All the existing holes were so packed tightly with wires and on top of that, the rubber gromet were zip tied. I finally found that small wire that Jack mentioned. I was afraid it was going to be tight also, but from the inside, I shoved a bbq stick thru what I later found out was just "black putty" used to seal the hole and wham! It was the best feeling because I was minutes from giving up. Now I've got a rocker switch to control the kitt scanner from the inside. Thanks for all your help.
Old 02-22-2012, 08:03 AM   #10 (permalink)
2010 Toyota Corolla XRS
JesseBand's Avatar
View JesseBand's Photo Gallery
wow, i have been at this for weeks. glad i found these posts.
|| 2010 MGM Toyota Corolla XRS ||
| 6000k HIDs & Fogs | Weapon-R Throttle Controller |
JesseBand is offline   Reply With Quote
