Fried wires trying to hook up LED strip - Toyota Nation Forum : Toyota Car and Truck Forums
Old 03-25-2011, 05:10 PM   #1 (permalink)
markymark975
markymark975's Avatar
View markymark975's Photo Gallery
Just got an LED strip light (knight rider light) and hooked it up directly to the battery and controlled via cheap wireless remote.
Was working fine but I decided I wanted to wire it to a toggle switch inside of the car.
I did alot of research then finally did it according to a wiring diagram I found, but instead of connecting the negative to the chassis, I wired it directly to the negative side of the battery.
I got it to turn on for a while, but when I switched it off, both wires to the battery melted, but only up to about a foot after the battery.
What did I do wrong??? I have the wiring diagram below.
Shoot..How do I embed a picture on here???
C:\Documents and Settings\Mark & Lisa\Desktop\My Pictures\2011_03_25\IMG_5052.JPG[/URL]
markymark975 is offline   Reply With Quote
Old 03-25-2011, 05:41 PM   #2 (permalink)
Gameroom cash: $282005
View Dragon-88's Photo Gallery
embed pictures using photobucket.com or any other host for pics.. I'm pretty sure you can use your car domain aswell.
Most forums dont allow adding pics as this takes up bandwidth.. Which is why you have to use the picture hosts.
Dragon-88 is online now   Reply With Quote
Old 03-25-2011, 06:57 PM   #3 (permalink)
markymark975
Ok let's try this..
Old 03-25-2011, 07:13 PM   #4 (permalink)
Boy Wonder
ChancreScolex's Avatar
Gameroom cash: $210651
iTrader Score: 6 reviews
View ChancreScolex's Photo Gallery
I assume you had to use extra wire so what gauge was it? Did you use an inline fuse?
2009 MGM Corolla S - My Garage
Debadged, Hood Dampers, Takeda SRI, 25/15 Tint, LED Dome/Map/License Plate Lights, Weathertech Rain Deflectors, Hella Supertones, Pioneer Premier AVIC-F90BT, 2 12" Pioneer Premier 1200w subs, Magnaflow Exhaust, TRD RSB/FSB/Springs, 18" Enkei EKM3's
ChancreScolex is offline   Reply With Quote
Old 03-25-2011, 07:32 PM   #5 (permalink)
Go Bills!
Digital_Jedi's Avatar
Gameroom cash: $112100
View Digital_Jedi's Photo Gallery
"I got it to turn on for a while, but when I switched it off, both wires to the battery melted, but only up to about a foot after the battery."
You will have to look at your switch for the appropriate pin outs, but it seems as if you shorted out the wires across the battery terminal. When the switch was in the "off"m position it was most likely connecting your two battery wires causing a rush of current which would explain the melting.
Unless your switch contains a light, you shouldn't really need a ground on it for this type of application. Double check the switch to make sure you are putting the wires on the appropriate pins.
09 Corolla CE: TRD FSB/RSB.TEIN S-tech Springs. Takeda SRI, Borla Exhaust, 3000k fogs,Mirimoto HID custom retrofit, Pivot TC, 17" gunmetal rims, vinyl light covers, rear window spoiler, D-din touchscreen, 20% tint all around, LED internal lights, Blacked out roof, GT Sport Full lip kit
Digital_Jedi is online now   Reply With Quote
The Following User Says Thank You to Digital_Jedi For This Useful Post:
shotgunjimmy (03-25-2011)
Old 03-25-2011, 08:21 PM   #6 (permalink)
HellaAverage
Jackss731's Avatar
Gameroom cash: $406100
View Jackss731's Photo Gallery
alright the only reason you would connect the switch to the ground is because you have a tiny led in the switch to signify you that the switch is on.
the switch is to cut off the flow of electricity.
so you should only need both RED wires to the switch.
judging by the way you drew your schematic....try one red wire to the middle+ and the other red to the negative-
flow ,even through a switch goes from + to -
so when you wired it it went from + to + so you didnt do anything but you grounded it so it went all crazy...
if you want me to draw up something let me know.
at least you had it working before so you know its only a switch problem :]
Jack
2010 Corolla S MGM
Thunder Low, OEMk Fogs, Blacked out emblems, Hella Horns, Eyelids, Blacked out wheels,
Jackss731 is offline   Reply With Quote
Old 03-26-2011, 04:38 PM   #7 (permalink)
markymark975
I went out and got an automotive 2 prong rocker switch instead. I didn't want to mess with the 3 prong switch and looks like we're in business. Thanks again.
Old 03-26-2011, 07:34 PM   #8 (permalink)
Unofficial TN Member
Shft99's Avatar
Gameroom cash: $444285
View Shft99's Photo Gallery
^ Yep cant go wrong with the 2 prong rockers. And yeah the negative side is where the problem was. If you planning on installing a lighted rocker switch-
2009 Corolla S | Magnetic Grey Metallic
Shft99 is offline   Reply With Quote
Old 03-27-2011, 11:59 AM   #9 (permalink)
Go Bills!
Light looks pretty nice! Glad you got it all sorted out...
Old 03-27-2011, 01:22 PM   #10 (permalink)
HellaAverage
Jackss731's Avatar
no prob!
Jack
2010 Corolla S MGM
Old 03-27-2011, 02:13 PM   #11 (permalink)
Dimaoala's Avatar
Gameroom cash: $874950
View Dimaoala's Photo Gallery
Ah today is my day off, finally get to get some rest
Woke up at 3 in the morning on friday, worked till 11, went to my 2nd job at 4 in the afternoon, worked till 1:20'ish in the morning. Woke up at 3 again, and worked till 12 in the afternoon. Got knocked out once I laid on my bed!
Getting some cash flow for some new mods! Or maybe its just time to start saving...
My 2009 Super White Toyota Corolla Xrs
Click my Signature to check out my CarDomain Profile!
Dimaoala is offline   Reply With Quote
Old 03-27-2011, 02:33 PM   #12 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
bro you need more rest, this is the wrong thread. lol
it seems like you fixed your problem which was shorting the battery out and not having a inline fuse.
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 03-28-2011, 11:15 AM   #13 (permalink)
markymark975
Do you think I really need an inline fuse? I actually bought one but I bought the wrong size fuses for the holder. I guess I'll install it for peace of mind.
Dimaaola, Seems like you have a busy schedule. What mods could you possibly need that you don't already have lol.
Old 03-28-2011, 11:29 AM   #14 (permalink)
HellaAverage
Jackss731's Avatar
BC coilovers!!!!!!!!!!
Jack
2010 Corolla S MGM
Old 03-28-2011, 12:14 PM   #15 (permalink)
Gameroom cash: $157000
View pinoyesv6's Photo Gallery
yes
pinoyesv6 is offline   Reply With Quote
