So I just got an alignment done this morning. The right rear toe numbers are out of spec as well as the total rear toe number. The guy said he could shim the right rear to get it back into spec.
My question is should I have a dealer look at it. I installed my Eibach springs about a week and a half ago so would the dealer give me trouble since I swapped out my springs? From my understanding installing lowering springs will not change any alignment measurements in the rear.
What does everyone think? The guy quoted me $150 to install the shims and get everything into spec. He only charged me $50 for the alignment.
the toes will always be off...i asked my friend (asst. manager of firestone) are always off of the toe. He said u can shim it but the shims are wood which will eventually fall out and be off again. not worth it cuz it shoudlnt be too off neways
2009 Corolla S Magnetic Gray Auto
Limo Tints|K&n Typhoon Intake|Upgraded Premium Horn|Smoked Tails, Reflectors & fogs||HID Kit FOG & Heads 6000k|TRD Lowering Springs|TRD FSB|TRD RSB|Wicked flow muffler|Weathertech Vent Visors|Keyhole Plugs|Calvin vinyl
Future:
JDM front lip|Headers|17in rims
Toe will always be off of 0 toe I agree. But when they're out of factory spec that isn't exactly the best situation. If Toyota publishes a rear toe range and they're outside of that then you probably can expect some tire wear.
Shims are made of either metal or plastic not wood. Not sure who would use a wood shim for an alignment purpose. It sounds like a lot of Prius owners have done the shim in the rear and had success. The right rear toe is off enough that over time it will cause more wear.
This company seems to be the popular choice among Prius owners who have shimmed the rear to get within spec:
Whoa whoa, anyone putting wood in there should not be working on a car. Also, if it did fall out, you'd have loose bolts holding your wheel bearing/hub on the car, that's not just out, it's entirely, 100% unsafe and very dangerous.
Most shims are plastic or metal. Toyota doesn't recommend using them, I haven't seen any issues arise from their use really, but if you aren't having any problems (pulling, tire wear), I wouldn't touch it.
Toyota will only do something if they can verify that the overall toe is out on the axle beam. If that is the case, they will replace the axle beam (or should, in my opinion), however I've seen them be just as bad afterwards as before.
As for the toe, lowering the car does not affect the toe setting on the rear.
Flame....have you had a dealer look at it? Or are you just going to live with it?
Ive already lived with it like that for a year. i havent seen abnormal tire wear, so i figure id live with it. I might try to correct it in the future with alignment shims but right now it doesnt cause any problems so there isnt a necessary need for shims.
I installed the eibach pro kit and I drove it for about four weeks before I had it aligned yesterday and the only thing out was the toe on the front.
Me too, the rear toe was fine.
__________________ 89 Supercharged White MR2 5-speed / 09 Corolla S CSM 5-speed
