Amplifier/Subwoofer Power Wire Isntall - Toyota Nation Forum : Toyota Car and Truck Forums
Old 04-30-2011, 12:12 AM   #1 (permalink)
2010 Toyota Corolla XRS
JesseBand's Avatar
View JesseBand's Photo Gallery
Honestly guys, I have searched and searched and searched and searched for a place to run the power wire from the battery and in to the car, with no luck whatsoever.
i could not find a usable grommet or anything of that nature.
can somebody please give me a moderately detailed explanation as of where I can do this at, or a pictured DIY if it exists for our vehicle.
Thanks a ton, guys.
|| 2010 MGM Toyota Corolla XRS ||
| 6000k HIDs & Fogs | Weapon-R Throttle Controller |
JesseBand is offline   Reply With Quote
Old 04-30-2011, 04:04 AM   #2 (permalink)
10th Gen. Corolla S Owner
SaltySteve's Avatar
View SaltySteve's Photo Gallery
Check this thread. I believe what you're looking for is in the last few pictures on post #7. I searched "firewall". Hope this helps.
2010 Corolla S BSP
~ TRD Lowering Springs ~ TRD FSB ~ TRD RSB ~ Weapon-R I-Throttle Controller ~ Kenwood X994 ~ 35% 3M Tint ~ 3M Clear Bra ~
SaltySteve is offline   Reply With Quote
Old 04-30-2011, 07:15 AM   #3 (permalink)
Jzen16's Avatar
Gameroom cash: $343301
View Jzen16's Photo Gallery
Thanks a ton, guys.
poke a hole in that rubber thingy
2010 Blue Streak Metallic, Corolla S
Jzen16 is online now   Reply With Quote
Old 04-30-2011, 01:58 PM   #4 (permalink)
rieds
Gameroom cash: $145495
View rieds's Photo Gallery
i ran mine in between the rubber piece with the bundle of wires running thru it and the two heater core lines on the drivers side. i didnt know if it was a good idea to disturb the rubber piece around those wires cause its made to seal around the wires so i drilled a hole and put a rubber grommet in the hole then caulked it with clear silicone caulk. hint: use a hole punch so the bit doesnt slide around and a small pilot bit to drill the hole then re-drill it with your big bit. make sure the bit is the diameter of the outside diameter of the hole in the grommet not the inside diameter. i have sri/cai and there was plenty of room to drill. if you have the stock airbox you might have to remove it.
FS:K&N drop in filter for 1.8 10th gen corolla. used for about three months. 15.00 + shipping.
FS: stock 16x6.5 corolla S wheels (no tpms) 300.00 + shipping. will throw in the stock goodyear rsa 205/55-16 tires if you want them. 20,500 miles on them.
rieds is offline   Reply With Quote
