oh yea these p.r guys go hard lol. 2zz on everything.. xd.. yaris. and so on.. from there they go all motor for more bragging rights lol
well ima bring some more goodies from the xd club
With the intake manifold... yes, intake manifolds are mostly best for f/i .. on the other hand we had a company by the name of dynatek who made a concept of the intake before their company fled from the scene. we had a dyno run and heres what we had so far
Here are the dyno results of the new long-tube header for the 1.8L Yaris TS and Scion xD (possibly other apps as well).
Equipped with just a home-made air intake, the otherwise stock Xd produced 123 wheel hp and 121 ft-lb of torque.
Equipped with the long-tube headers and 2.5-inch mid pipe (2.25 would work equally well) and no axle back, the motor produced 134 wheel hp and 134 ft-lb of torque.
At just 3000 rpm, the header and mid pipe offered an additional 15 ft-lb of torque.
Next we installed the prototype of the Xd intake manifold. The peak power numbers jumped to 148 hp and 137 ft-lb of torque.
At 6000 rpm, the intake offered gains of 16 hp.
It appears from this testing that if we add an NST u-pulley and receive the same results as we did on the 1.5L Yaris motor, the 1.8L can produce a real 150 wheel hp (possibly more if it reponds favorably to the FIC).
don't believe me?
heres the sheets
Now you say 200 hp... well w/o haven't it stroked.. probably wont happen but we can certainly get close.. Perhaps 170- 180ish at the crank? but its gonna require some internal work i.e pistons.
uhmm.. again with an intake. full exhaust intake mani. nst pulley.. probably 150hp? our engines uses the same fuel injectors except is less output.. add tc fuel injectors .. if we can get pistons.. we can be looking at 7-12hp... to finish it off. with a good a** tune.. probably another 10-15hp. Now I know we can get bc to make us cams.(i want that!) pistons( that too) and valve springs (nd def, that!) we be set! I mean with corolla. xd. vibe. yaris and other cars with 2zr. Im pretty sure we can get 10-20 interested. any thoughts?
