How do you fill manual trans fluid, 2009 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 05-19-2011, 03:06 PM   #1 (permalink)
View seataccruiser's Photo Gallery
Ok all corolla gurus's out there. I've got a 2009 s with 5 speed manual. I need to change the tranny oil, found the drain plug, how/where do you fill it??
thanks! I appreciate your help.
seataccruiser is offline   Reply With Quote
Old 05-19-2011, 09:55 PM   #2 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1341666
iTrader Score: 7 reviews
Look toward the front of the transmission on the side up from the drain plug & you will see the filler plug, it's the same kind of bolt as the drain bolt. Always loosen the fill bolt first before draining your gear oil in case you can't get it loose to refill the transmission. I used a funnel with a long cleat plastic tube that I stuck into the fill hole. The tube will go down just to the left of your battery. It takes 2 quarts exactly & use Redline MT-80 for the best protection.
ROTM November 2011 Winner!
SuperchargedMR2 is offline   Reply With Quote
