"N" Gear - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-03-2011, 09:57 AM   #1 (permalink)
View wec12's Photo Gallery
"N" Gear
Would it be better to gas milage if I switch to N when waiting for the green light to come on at the intersection? Would it do something bad to transmission? Thanks.
wec12 is offline   Reply With Quote
Old 06-03-2011, 10:07 AM   #2 (permalink)
Gameroom cash: $123850
View c_huynh32's Photo Gallery
Auto or manual?
If auto, it won't save anything really, ... bad for transmission? ... no it's not, just change your fluids frequiently then you should be fine.
c_huynh32 is offline   Reply With Quote
Old 06-03-2011, 10:09 AM   #3 (permalink)
Need For Speed
arabianobsession's Avatar
Gameroom cash: $1105000
View arabianobsession's Photo Gallery
Well, here's the thing. While you're idling at a stop light, your RPM's are so low that it's kind of useless to drop it into Neutral. I've seen people do it down hills, or when they're coasting to a light, but not idling at a light.
Another issue is that sometimes you forget you put it in Neutral, and when you go to take off, you just rev your car really high and you don't go anywhere.
6 speed manual 2011 Camry SE
2012 Honda Accord Coupe---1995 Ford Mustang---1985 AMC Eagle
arabianobsession is offline   Reply With Quote
Old 06-03-2011, 10:19 AM   #4 (permalink)
CERTIFIABLE CAR NUT
Zembonez's Avatar
Gameroom cash: $616531
View Zembonez's Photo Gallery
Let your car handle the efficiency. You can't improve on what the computer is doing by manually tricking it. In fact, all of that switching from D to N is probably not going to do your trans any good.
Zembonez is offline   Reply With Quote
Old 06-03-2011, 10:49 AM   #5 (permalink)
on full afterburner
Gameroom cash: $1347897
I wouldn't.
Just in case you find yourself having to get out of harms way in a hurry.
Fuel economy benefit is debatable and negligible at best.
Old 06-03-2011, 10:58 AM   #6 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521219
View LeanBurn's Photo Gallery
Canada
Like others have said, the answer is no. It will actually yield worse fuel economy. DFCO (decelerate fuel cut off) will not activate while in "N". You can check this for yourself by watching your instant fuel consumption readout on your dash. Don't switch to "N" down hills slowing to an intersection either, it will hurt your fuel economy. Let the computer do its job.
In addition switching gears from N to D constantly activating different pump areas in the auto trans leads to accelerated wear.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
