2009 Corolla LE electrical wiring questions (keyless entry) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 06-04-2011, 09:31 PM   #1 (permalink)
View tchiman27's Photo Gallery
I'm trying to wire in a keyless entry system into my 2009 corolla and need some input before I proceed. I need a +12V Battery and a +12V Accessory which I believe can be located on connector E4 in the steering column (the one with the white connector under the ignition cylinder in the picture below). Have I identified E4 correctly and is the red wire on the connector +12V Battery and the Gray wire (the one with two wires coming out of it) +12V accessory?
Also, I need to locate: 1. Driver's Door lock motor, 2. Door Unlock Switch, 3. Door Lock Switch on connector IE2 and Door Unlock Detect Switch on connector IE1. Have I identified the connectors and signals correctly in the picture below?
Any help would be much appreciated!
tchiman27 is offline   Reply With Quote
Old 06-10-2011, 02:06 AM   #2 (permalink)
anyone?
