Can we get an aftermarket parts thread for the 2011 Corolla's? or do the 09-10 corolla parts fit ours as well? ( I realize if they do fit this is a unless thread that should be deleted) but I cant find any answer anywhere saying if anything or everything for a 09 or '10 will fit a 2011, any help or answers would be appreciated thanks
not EVERYTHING will fit the '11 corolla. I believe the only things that will NOT fit the '11 corolla have to do with cosmetics. For instance... the tail lights, head lights, grill+front bumper.
With that being said... I would be willing to bet that the connections for both '09-'10 & '11 are all the same. so if you wanted to swap the front bumper and headlight setup, it should all bolt together using the same holes.
In the end... Trial and error is going to be your only real friend...(-having a dealership connection that knows the repairs for both the '09-'10, and '11 models)
2009 Toyota Corolla S
TRD Front Strut Tower Brace, Injen Cold Air Intake, Borla Axle-Back Exhaust, Drag DR-12 17"
Coming soon: Springs, Sway bar, Brake lines, and decals http://www.cardomain.com/ride/3883430/1
no im not worried about anthing the bumpers, cosmetics, etc. i meant like intake, exhaust, (an we have the same engine so those should fit right?) and the TRD springs, strut bar an RSB (being TRD parts toyota makes an we have same suspensions in 2011's an 09-10 those should fit as welll or no? thats my main concern guess i shouldda stated that in first post too
I think the only problem you will run into is if you get the parts installed at a dealership. If the parts are not SPECIFICALLY made for your car, then the dealership will most likely not honor a warranty and might even make you sign a waver incase something happens.
However, if you let the dealership install the parts, you should .
Unless ofcourse they do it for FREE... then you should...
All mechanical & suspension parts will fit perfectly, the 11 is still part of the 10th Gen family!
__________________ 89 Supercharged White MR2 5-speed / 09 Corolla S CSM 5-speed
That is correct.
