repairing front end damage to rad support that pushed fenders out - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-16-2011, 08:27 PM   #1 (permalink)
View iMPFAC's Photo Gallery
Howdy, I've never posted but I lurk here all the time, but this is one I've not found a satisfactory answer to:
I hit an SUV doing around 5mph and his bumper was high enough to push into my grill. It cracked the bumper and smooshed the upper tie bar/radiator support in just a little-enough that it pushed both fenders out under half an inch and it broke the mounting bracket on the pass side headlight. Everything works and 3 different shops have looked at it and say it just needs to be straightened, to the tune of $1200 to do everything.
I can do everything but am hesitant about the smooshed out fenders.
Is it ok to use a come along and and tree and pull it straight myself? Any tips?
http://i207.photobucket.com/albums/b...7-16190517.jpg
http://i207.photobucket.com/albums/b...7-16190559.jpg
http://i207.photobucket.com/albums/b...7-16190608.jpg
http://i207.photobucket.com/albums/b...7-16190705.jpg
iMPFAC is offline   Reply With Quote
Old 07-16-2011, 10:00 PM   #2 (permalink)
2010 Corolla S
Gameroom cash: $230908
View TFCommanderBob's Photo Gallery
Embedding for ease-of-use... No advice other than using a tree sounds scary.
TFCommanderBob is offline   Reply With Quote
Old 07-17-2011, 12:56 AM   #3 (permalink)
thanks, I couldn't figure out how to do that =)
Old 07-17-2011, 06:18 AM   #4 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
1200 seems like a good deal...i wouldnt try to do that myself.
Bay Area Corolla
flamedrgn is offline   Reply With Quote
Old 07-17-2011, 08:13 AM   #5 (permalink)
Toyota Addict
Gameroom cash: $190660
View clintj's Photo Gallery
Good luck with that... The shop will use tram gauges and most likely laser measuring to get everything back to factory spec dimensions. Not being square can cause all sorts of problems from handling and alignment to anything else. Also if you over pull you may cause even more damage. However, I doubt with a comealong and a tree you will be able to pull that sufficiently.
Your gaps may have been changed by 1/2" or more on both fenders however I guarantee that it will need to be pulled a lot more than that.
clintj is offline   Reply With Quote
Old 07-17-2011, 04:46 PM   #6 (permalink)
I actually got an even lower one for 940. I think I'll get the parts off ebay and have the straightening work done professionally, not painting the replacement bumper should help with cost and I'd be saving like 150 on the parts.
any tips on what should I ask the guy to make sure he's doing the straightening correctly and I'm not paying for the sort of half assed work I can do?
Old 07-17-2011, 04:59 PM   #7 (permalink)
Toyota Addict
- To not painting replacement parts.
I would highly recommend making sure any non-OEM replacement parts are CAPA certified. Even then CAPA certified parts have something like a 40% failure for fitment.
As to your question - Just ask the body shop what kind of system they use for pulling and measuring.
Old 07-17-2011, 07:48 PM   #8 (permalink)
Gameroom cash: $457387
View cabur's Photo Gallery
+1
Inspect the shop to see what equiptment he have to do the work. If you see a big tree with a chain around it, go to another shop.Ha ha.
LE, Smart Key, Limousine tint, Back-up sensor. M.I.C. 7" DVD.
cabur is offline   Reply With Quote
Old 07-17-2011, 07:49 PM   #9 (permalink)
Double post.
Old 07-18-2011, 01:25 AM   #10 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1342366
iTrader Score: 7 reviews
Just fix it right the first time & you will save a lot of money in the long run.
ROTM November 2011 Winner!
SuperchargedMR2 is online now   Reply With Quote
Old 07-18-2011, 04:26 AM   #11 (permalink)
flamedrgn's Avatar
i agree with everything above. you get what you pay for, so dont be cheap on something because the next repair might cost you more because this one wasnt fixed right.
Bay Area Corolla
