Aux In Question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 07-25-2011, 10:41 PM   #1 (permalink)
View jtphl's Photo Gallery
Aux In Question
Would anyone know here how to "enable" the AUX in?
I run into Diagnostics and I saw " AUX --" in LCD, which makes me think that my Radio is Electronically Aux in Ready but physically not able to do so maybe because due to lack of wiring, my unit didn't came with a Aux in port. Anyone here knows how I can enable such function?
Thanks.
jtphl is offline   Reply With Quote
Old 07-26-2011, 04:00 AM   #2 (permalink)
Gameroom cash: $157000
View pinoyesv6's Photo Gallery
on the us models, there are two sets of wiring in the connector that plugs the radio into the aux port. 1 set of wires carries the audio signal from the aux port to the radio itself. the other set of wires senses that something is plugged into the aux port and enables the aux setting on the radio.
i would first start off by pulling the radio and seeing if there is capabilities for an aux input and possibly some wiring for it to. it might be as simple as plugging some things in and buying an aux port.
pinoyesv6 is offline   Reply With Quote
Old 07-26-2011, 04:50 AM   #3 (permalink)
Yes, that's right I must start first by knowing whether my radio can accept aux in, but where do I start? Which pins do I have to check?
Old 07-26-2011, 10:05 AM   #4 (permalink)
Gameroom cash: $142200
View toyotas4all's Photo Gallery
If you pull out your radio and look in the back it should be the 20 pin plug.
toyotas4all is offline   Reply With Quote
Old 07-26-2011, 11:14 AM   #5 (permalink)
I believe my radio is equipped with that kind of 20 pin connector, so what's next? How do I check whether my radio is AUX IN ready?
Old 07-26-2011, 11:33 AM   #6 (permalink)
My apologies, it is not the 20 pin connector, its actually the 12 pin connector. You might have to ask someone to take a picture of their unit and compare it to yours. See which pins are missing.
I'll actually be taking apart my steering wheel to put the steering wheel controls in this week (if I have time), and I'll snap one for you.
Old 07-26-2011, 11:46 AM   #7 (permalink)
I think I found on the net some information about the pins, but I am not sure how to test the AUX IN, I am afraid that connecting 2 wires might lead to short circuit. You can check this site http://www.yarisworld.com/forums/showthread.php?t=11849. I don't know whether I shall connect body ground and AUX0 to test the AUX in.
Old 07-26-2011, 04:57 PM   #8 (permalink)
2010 Corolla S
Gameroom cash: $230908
View TFCommanderBob's Photo Gallery
So many AUX threads, so little time!
Here is a pic of the back of my S's radio, if it helps.
I ripped the guts out of my jack and used the faceplate and housing to mount a 3.5mm extension cable, and the other end will be plugged into my Car PC. Just mounted a card-reader/usb/2.5"-drive-bay in where the security and seatbelt lights used to be too. Now I've gotta figure out what I want the other blank to be...........
I would assume all the wiring to be present, both in the radio and in your factory harness. I've found so many little white ends throughout the car which serve me no purpose, but must be for something for someone. I'm guessing most stuff is cheaper for them to just make 1 off with no changes.
TFCommanderBob is offline   Reply With Quote
