Originally Posted by ChosenGSR
I feel a little dumb asking this but where are the jacking points under the corolla? Every car I've owned had clearly market jack stand placement points with "hockey pucks". I looked under the corolla yesterday and not only does the side skirt plastic extend a good 3" in, but the only thing I found resembling hockey pucks were a couple of rubber plugs. Am I missing something obvious?
Side question, as far as replacing the air filter is it as simple as un-clipping the air box, dropping the filter in, and clipping the box back on?
Thanks
As far as jacking the car up with the included jack I just insert it through the protruding vertical tab and jack it up...as far as the jack stands, I believe the upside-down U indentation is where you would set the jackstand upon it.
And if you got the drop in air filter kit like the K&N Drop In, then yes it pretty much is pull the tabs, pull out the stock filter, drop in the aftermarket in the "right" way (the way it's shaped should indicate only one way to put it, then close it...
I recommend downloading the repair manual I recently posted for more information
