stupid fly! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-11-2011, 01:38 AM   #1 (permalink)
TN Member
Simply Clean's Avatar
View Simply Clean's Photo Gallery
stupid fly!
This fella got stuck inside my taillight how do I get it out?
Simply Clean is offline   Reply With Quote
Old 09-11-2011, 01:56 AM   #2 (permalink)
littleboi64's Avatar
Gameroom cash: $284402
View littleboi64's Photo Gallery
read up on swapping taillight/rear blinkers and jam a vacuum cleaner hose in there and try to suck it out
littleboi64 is offline   Reply With Quote
Old 09-11-2011, 03:53 PM   #3 (permalink)
joeylgarcia's Avatar
Gameroom cash: $186655
View joeylgarcia's Photo Gallery
worst is you have to cut the plastic back of your tail light to remove that fly.
2009 Corolla S auto Blue Streak Metallic
joeylgarcia is offline   Reply With Quote
Old 09-11-2011, 08:46 PM   #4 (permalink)
TN Member
How do I remove my tail lights and remove the cover too?
Old 09-11-2011, 09:27 PM   #5 (permalink)
on full afterburner
Gameroom cash: $1347897
There is a DIY floating around somewhere here.
In order to open the housing, you'll have to bake your taillight in the oven on low heat just enough to melt the glue and pry the housing apart.
Old 09-12-2011, 01:00 AM   #6 (permalink)
Unofficial TN Member
Shft99's Avatar
Gameroom cash: $444285
View Shft99's Photo Gallery
^ and fry the fly in the process
2009 Corolla S | Magnetic Grey Metallic
Shft99 is offline   Reply With Quote
Old 09-12-2011, 12:59 PM   #7 (permalink)
Gameroom cash: $457387
View cabur's Photo Gallery
I'd leave it.
To remove it, use a small tube preferrably 1/8" clear tubing through the bulb opening with suction. Either a vac. vac. bulb, or just suck. Be very careful though or it'll end up in your mouth. ha ha.
LE, Smart Key, Limousine tint, Back-up sensor. M.I.C. 7" DVD.
cabur is offline   Reply With Quote
Old 09-12-2011, 01:54 PM   #8 (permalink)
View HarleyCVO's Photo Gallery
Maybe you should put a cricket in there
HarleyCVO is offline   Reply With Quote
Old 09-12-2011, 02:28 PM   #9 (permalink)
Shft99's Avatar
Crickets don't eat flys. Frogs do. So put a frog in there and your fly problem is solved... But in all seriousness. Just vacuum it out through the bulb opening.
Old 09-13-2011, 04:08 PM   #10 (permalink)
you could use a dremel tool to cut out near the sides of the backing of your tail light. then reglue it back.
