Are these defective? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-12-2011, 10:13 PM   #1 (permalink)
TN Member
Simply Clean's Avatar
View Simply Clean's Photo Gallery
Got my coilover in today and I was sooooooo
Until I found this out and i was and !! Motherfdsfkdsfsdf hope these two arent defective.
Front pillowball to be seem slanted
Rear coilover dust cover seems to be crooket and rear pillowball seem to be slanted
Simply Clean is offline   Reply With Quote
Old 10-12-2011, 10:18 PM   #2 (permalink)
pengin978's Avatar
Gameroom cash: $294650
View pengin978's Photo Gallery
holy...
could you move the front top mounts at all?
the rear... check the bolt up top where the damping knobs are, are they loose?
edit: congrats that you bought megans'!!
pengin978 is offline   Reply With Quote
Old 10-12-2011, 10:43 PM   #3 (permalink)
TN Member
Originally Posted by pengin978 View Post
holy...
Thanks
yes the bolts on top are loose is this bad
oh i cant move the front top mount at all so are these defective?
Old 10-12-2011, 11:07 PM   #4 (permalink)
pengin978's Avatar
if the bolts are loose, adjust the plates and then tightened it up. see if it straights up. megan's come loose like that for some reason. but once tightened its wouldn't happen again.
Old 10-12-2011, 11:33 PM   #5 (permalink)
TN Member
Sorry I'm so noob to this how do I loosen these bolts, do I need a spring compressor to secure the spring from popping out at me while im doing this or i just have to remove the bolts on top of the pillowball including the damper adj as well and after removing the bolts I just have snap the dust cover and pillowball to it straight position right? so confused and worried as well too!
