2009 Corolla Starter - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-18-2011, 02:17 PM   #1 (permalink)
View Thomaswett's Photo Gallery
Canada 2009 Corolla Starter
Can I get the instructions so I can replace repair the starter on the 2009 Corolla?
Thomaswett is offline   Reply With Quote
Old 10-18-2011, 03:33 PM   #2 (permalink)
flamedrgn's Avatar
Gameroom cash: $480969
View flamedrgn's Photo Gallery
REMOVAL
1. DISCONNECT CABLE FROM NEGATIVE BATTERY TERMINAL
2. REMOVE TRANSMISSION OIL FILLER TUBE SUB-ASSEMBLY (for Automatic Transaxle)
3. REMOVE STARTER ASSEMBLY
(a) Remove the terminal cap.
(b) Remove the nut and disconnect terminal 30.
(c) Disconnect the connector.
(d) Remove the 2 bolts and starter assembly.
INSTALLATION
1. INSTALL STARTER ASSEMBLY
(a) Install the starter assembly with the 2 bolts.
Torque: 37 N·m (377 kgf·cm, 27ft·lbf)
(b) Connect the connector.
(c) Connect terminal 30 with the nut.
Torque: 9.8 N·m (100 kgf·cm, 87in·lbf)
(d) Close the terminal cap.
2. INSTALL TRANSMISSION OIL FILLER TUBE SUB-ASSEMBLY (for Automatic Transaxle)
3. CONNECT CABLE TO NEGATIVE BATTERY TERMINAL
Bay Area Corolla
flamedrgn is offline   Reply With Quote
The Following User Says Thank You to flamedrgn For This Useful Post:
Thomaswett (10-18-2011)
Old 10-18-2011, 03:44 PM   #3 (permalink)
Smile 2009 Corolla starter
that is exactly what I needed. Thanks so much
Old 10-18-2011, 03:47 PM   #4 (permalink)
Canada 2009 Corolla starter
Do I have to remove the starter from underneath or can I reach it from the top?
Old 10-19-2011, 08:34 AM   #5 (permalink)
Thanks work completed
