HIDs high beam question 9005 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-19-2011, 01:17 AM   #1 (permalink)
View mitchellhdz's Photo Gallery
I was wondering if anyone has had problems with HIDs in thier DRLs. I heard that they need a relay, i just wanted to make sure they wont flicker.
2010 corolla S
mitchellhdz is offline   Reply With Quote
Old 10-19-2011, 07:38 AM   #2 (permalink)
uh..no, it's not a hybrid
LeanBurn's Avatar
Gameroom cash: $521219
View LeanBurn's Photo Gallery
Canada
HID kits in general are illegal: Mandatory Viewing Before Considering HID Conversions.
HID high beams glaring uncontrolled in place of DRL's is plain dangerous on top of that. Its like driving with your high beams on all the time, but brighter than the law allows.
Not sure what the purpose would be other than irritation to those around you. Even at night HID high beams couldn't be used in rural settings, they should always be dipped to low when encountering traffic. Using HID highs in the application would result in constant on/off operation causing much much shorter lifespan.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated)
(original unflashed factory ECM code)
LeanBurn is offline   Reply With Quote
Old 10-19-2011, 01:08 PM   #3 (permalink)
Gameroom cash: $418600
View tengiday's Photo Gallery
DRL runs on reduced power, so putting HID in high beam results the bulb flickering and damaging it. Unless you disable the DRL or use a relay, you can't install HID in your high beam.
2008 Toyota Camry LE I4 - Modifications as if they come with the car.
- TRD wheels, TRD suspensions
- OEM replica navigation with iGo/Tomtom/...
- Folding LED signal side mirrors with JDM control switch
- HID retrofit headlights with S2000 projectors and Denso ballasts, fog lights
tengiday is offline   Reply With Quote
Old 10-19-2011, 01:49 PM   #4 (permalink)
Ur responce has nothing to do with my question leadburn sorry
Old 10-19-2011, 01:52 PM   #5 (permalink)
Cool thanx
Old 10-19-2011, 02:30 PM   #6 (permalink)
Automotive Lighting Guru
gold94corolla's Avatar
Gameroom cash: $291852
View gold94corolla's Photo Gallery
DRL and relays are separate topics.
1st, you'll need to disable the DRL.
2nd, the HID kit might have a flicker without a special heavy-duty relay kit to handle the extra current. But this flicker is not the DRL flicker. You can install an HID high beam, but HID kits tend to have a slow startup, which means you won't have a useable high beam for a few seconds. But once it does, and there is no flicker, it is mad bright!
gold94corolla is offline   Reply With Quote
Old 10-19-2011, 02:56 PM   #7 (permalink)
LeanBurn's Avatar
Canada
Old 10-19-2011, 04:07 PM   #8 (permalink)
Gameroom cash: $108950
View diablo2184's Photo Gallery
why did you put HIDs in your highs? I have in my lows and its more than enough light.....
2010 White Corolla S
-5% Tints, TRD FSB/RSB, more to come....
2008 Starfire Pearl IS-F
2006 Wicked White Lancer Evo IX
diablo2184 is offline   Reply With Quote
Old 10-19-2011, 09:17 PM   #9 (permalink)
that's because your lows aren't designed properly for HID so the light scatters up everywhere. You are basically driving with high beams on, glaring everyone.
Tags
hi beams, hids
