With the intervention of auto lighting and DRL circuitry its going to be difficult I think to separate them. Disconnecting auto light also disconnects DRLs. DRL only operates the high beams at a lower voltage with no low beams. While switching the headlights on allows both low and high beam operation at the same time, the high beams operate at full voltage, so the desired yellow effect will not be achieved.
'09 Corolla CE Enhanced Auto
TRD Springs/Sway/Xrs FSB by Yamaha
Lifetime : 6.121L/100km(38.714mpgUS)
Maximum: 5.082L/100km(46.287mpgUS)
(manually calculated) (original unflashed factory ECM code)
