2010 Corolla S towing capacity? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla Forum > 10th Generation (2009-2013) > 10th Gen General Discussion Forum
Old 01-29-2013, 01:01 PM   #1 (permalink)
View twnorton's Photo Gallery
Looking to tow my motorcycle (360lbs wet) and a small 4x6 trailer (500lbs max) will the corolla do it. I understand the motor will be under a heavier load so mpg is expected to decrease. It will be mostly highway towing as well. I would rather take the corolla than my grand cherokee that gets 15mpg
twnorton is offline   Reply With Quote
Old 01-29-2013, 01:44 PM   #2 (permalink)
Toyota Fanatic
hardtopte72's Avatar
Gameroom cash: $601050
View hardtopte72's Photo Gallery
Your corolla will probably get only marginally better if any fuel economy towing with a Corolla but you will experience some severe control and braking problems.
I would take the jeep or rent a truck.
My Toyota List:
1982 Corolla SR-5 Hardtop 1JZGTE R154
2005 Corolla CE Manual 1ZZFE
2009 Camry LE Auto 2AZFE
If I helped out in any way please hit the blue Thanks button on my post.
hardtopte72 is offline   Reply With Quote
Old 01-30-2013, 01:02 AM   #3 (permalink)
Diehard Rams Fan
SuperchargedMR2's Avatar
Gameroom cash: $1625366
iTrader Score: 7 reviews
I would think that it would tow it just fine. I've seen other 10th gens towing small trailers many times over the years.
94 Corolla DX Red 5-speed / 95 Previa S/C White Auto/
SuperchargedMR2 is offline   Reply With Quote
Old 01-30-2013, 01:06 AM   #4 (permalink)
Moderator
heartdisease's Avatar
Gameroom cash: $574070
View heartdisease's Photo Gallery
I also don't think you would have any trouble. My brother has an 87 Mazda 626 and we have been using it to tow a small 4x8 wood floored utility trailer loaded with probably 3-500lbs of stuff with absolutely no trouble at all. I am sure your Corolla has enough umph and brakes to handle it with some cautious driving. I would also think if you didn't try to cruise at 75-80 that the mpg would easily beat the 15mpg of the Jeep, I would guess high 20's.
<img src=http://i833.photobucket.com/albums/zz252/Heartdisease1/2013Chiefsresize_zpsc068a8f5.jpg border=0 alt= />
heartdisease is offline   Reply With Quote
Old 01-31-2013, 07:46 PM   #5 (permalink)
The random one
Gameroom cash: $123216
View MiniPacou's Photo Gallery
You will have no problem, I think the total tow capacity is around 1000lbs. Ive towed I 4x8 trailer with two wood stove with a total weight around 900 lbs with no problem. Mind you it was slow going uphill and hard on gas (13L/100km).
Got HIR?
MiniPacou is offline   Reply With Quote
Old 02-02-2013, 02:17 AM   #6 (permalink)
Toyota Fanatic
I thought you said more weight.
Still the fuel economy of a Corolla drops significantly by simply adding people.
I would wager you are only marginally better with the Corolla.
My Toyota List:
Old 02-03-2013, 06:21 PM   #7 (permalink)
CRESSIDA!!!
84Cressida's Avatar
Gameroom cash: $822070
View 84Cressida's Photo Gallery
Take your Jeep. It's a car, not a tow vehicle.
Sent from AutoGuide.com Free App
1991 Toyota Camry 14,000 mi
1994 Toyota Pickup 64,000 mi
1998 Toyota Avalon 143,000 mi
2005 Chevrolet Silverado 54,000 mi
2006 BMW 330i Sedan 110,000 mi
2007 Toyota Camry Hybrid 79,000 mi
84Cressida is offline   Reply With Quote
Old 02-03-2013, 08:17 PM   #8 (permalink)
Official Corolla Owner
tinbasher's Avatar
View tinbasher's Photo Gallery
I think the towing capacity is 1500lbs, which is quite high for a compact car. You shouldn't have any major problems, otherwise Toyota wouldn't say the car was safe to tow with.
tinbasher is offline   Reply With Quote
Old 04-06-2013, 04:39 PM   #9 (permalink)
View JRA2000TL's Photo Gallery
Just came upon this thread as I had to give up my 07 4Runner for an 09 Corolla S due to a significant increase in my daily commute (new job). I have an 06 Honda Aquatrax F-12X (3 seater). Dry weight is 792, trailer is about 200, a full tank of fuel is about 140, and misc. cargo in the ski only 20-30 lbs. That's an approximate total of 1160 lbs. The car is rated for 1500 as discussed; just not sure about handling or stopping ability.
I just came back from Lowes with 10 concrete blocks in the trunk and you could tell I had the extra payload. Just wondering if it would tear up the transmission. Car has 45k on it, and I'll do a drain/fill at 50k even though it has the WS fluid. 60k is recommended if you tow. Currently I put a hitch on my toy car (89 Taurus SHO) which has a 220hp V6 and easily pulls it. What's funny is that the SHO model is rated at 1000 lbs and the Corolla is rated at 1500. Keep in mind the SHO has the same suspension setup as a standard Taurus; so there's nothing special about it other than the engine/tranny combo. It is a 5spd as well.
Yeah I can go buy a $3000 truck but we have 4 vehicles and I take the ski out half a dozen times a year maybe. How does the Corolla do pulling the boat out of the water on the ramp?
I'm told you drive in D3. Do you use low gear to pull it out of the ramp? Any input is appreciated.
JRA2000TL is offline   Reply With Quote
Old 04-07-2013, 12:20 AM   #10 (permalink)
Diehard Rams Fan
I can't remember how many miles this guy had on his older, smaller Corolla but he's been using it for many years hauling this trailer with old appliances in it. No issues he said with anything, brakes, engine or trans.
Old 04-07-2013, 07:54 AM   #11 (permalink)
I'm the D.O for your B.O
Gameroom cash: $1745597
What a trooper!
Old 04-07-2013, 09:26 AM   #12 (permalink)
Moderator
Those engines are known to be torque monsters aren't they? I doubt the modern version is as torquey.
Old 04-07-2013, 09:52 AM   #13 (permalink)
willyb0b's Avatar
View willyb0b's Photo Gallery
though i think it always looks funny to see a sedan or coupe pull a trailer.... you will be just fine pulling your motorcycle
2010 Toyota Corolla - Base
2009 Lexus RX350 - Pebble Beach Edition
willyb0b is offline   Reply With Quote
Old 04-09-2013, 11:35 PM   #14 (permalink)
View Whiteout13's Photo Gallery
I found that an 09 can tow up to 1500 pounds so you should be fine. I'd take it on some lower speed roads first to see if it'll do okay. Then try it on the highway. Had a buddy that had an old two door lowered civic and towed a boat with it all the time and even towed a huge hot tub back from Tallahassee
Whiteout13 is offline   Reply With Quote
Old 05-08-2013, 01:34 PM   #15 (permalink)
View Promagstyle's Photo Gallery
Towing Capacity
Bro... you should be you just need a Class I hitch.
The towing capacity for 2010 Corolla's are: 1500lbs
Source: http://media.toyota.ca/pr/tci/en/toy...pdf?ncid=12930
Promagstyle is offline   Reply With Quote
