Leaking clear, odorless fluid...water? - Toyota Nation Forum : Toyota Car and Truck Forums
Corolla 10th Gen/2nd Gen Matrix General Discussion Forum A place to discuss all things 10th Gen Corolla and 2nd Gen Matrix.
post #1 of 13 Old 04-13-2010, 06:35 PM Thread Starter
Quoted: 0 Post(s)
(Thread Starter)
Noticed today that there is a leak coming from underneath my 2010 corolla le by the drivers side door. It's a clear, odorless liquid, and it starts to leak when engine warms up and the car is parked and idle. Didn't use the AC or anything like that. Any ideas on what it could be? I think it is water but why the heck is it leaking?
jackman61 is offline
post #2 of 13 Old 04-13-2010, 07:42 PM
Senior TN Member
Quoted: 51 Post(s)
Was it raining or you've just washed the car?
It could just be the drain from the vents below your wiper.
LE, Smart Key, Limousine tint, Back-up camera and sensor. M.I.C. 7" DVD. Dashcam.
2016 RAV4 XLE Hybrid.
cabur is online now
post #3 of 13 Old 04-13-2010, 09:39 PM
Senior TN Member
joeylgarcia's Avatar
Quoted: 5 Post(s)
did u use the heater?
joeylgarcia is offline
post #4 of 13 Old 04-13-2010, 09:53 PM
Diehard Rams Fan
SuperchargedMR2's Avatar
Quoted: 1133 Post(s)
iTrader Score: 8 reviews
There are drain holes all around the car so if the car was parked on a slight incline it could have just been some water that ran to that side of the car & drained out. Just keep an eye on it to see if you can figure it out, I'll bet it's no big deal.
89 Supercharged White MR2 MT/09 Corolla S CSM MT/08 Yaris HB MT
94 Corolla DX Red MT/95 Previa S/C White AT/06 Scion xB MT/07 Corolla CE CSM MT/10 Prius III Blizzard Pearl
SuperchargedMR2 is offline
post #5 of 13 Old 04-13-2010, 10:10 PM
Dimaoala's Avatar
Quoted: 2 Post(s)
+1
Dimaoala is offline
post #6 of 13 Old 04-13-2010, 11:09 PM
FlameyFart's Avatar
Quoted: 0 Post(s)
The AC will turn on if the following 2 conditions are met even if the AC button is off:
1. fan is set to blow at the windshield, and
2. temperature is set to cool (blue, and maybe even some portions of white)
If that's the case, then the liquid is just condensation. Nothing to worry about.
2010 Corolla LE (MGM)
FlameyFart is offline
post #7 of 13 Old 04-14-2010, 10:26 AM
Quoted: 0 Post(s)
Not true. The system will simply force in air from outside at the lowest temperature available (i.e. unaltered air from outside). The compressor does not run.
Edit: After re-reading FlameyFart's post I realize I missed the key word and between the conditions, which considerably alters the meaning. My apologies to you, FlameyFart. Jeff has already explained the topic so please disregard my post.
2009 Corolla S - Magnetic Gray Metallic
|TRD Drop-in|Debadged|Pioneer Rears|30% Tint|
|30% Tint|
Nokya 2500k Fogs|Weathertech Vent Visors|
metalbones is offline
post #8 of 13 Old 04-14-2010, 10:52 AM
Owner of much Obsolete
Jeff Lange's Avatar
Quoted: 7 Post(s)
Temperature control never does anything other than temperature control. It will not change from recirc to fresh either. It only controls the temperature damper.
A/C is activated by the A/C button or by having the vent selection on defog/foot or defog. Fresh air is forced with the vent control set on defog/foot and defog.
Jeff
2011 Lexus IS350 6MT F-Sport with LSD
1986 Toyota Corolla GT-S Supercharged with TRD Stuff
1993 Toyota Previa 5MT Studded Ice Race Van
Jeff Lange is offline
post #9 of 13 Old 04-14-2010, 10:52 AM
Senior TN Member
Quoted: 51 Post(s)
Are you sure?
This was discussed extensively in '08 when the 10 gen first came out. Unless Toyota changed; compressor runs all the time when defrost is selected even when the A/C light is off.
cabur is online now
post #10 of 13 Old 04-14-2010, 11:42 AM
Jeff Lange's Avatar
Quoted: 7 Post(s)
Cabur: that is correct. (Unless other factors turn A/C off -- pressure switches, etc. as part of the A/C system).
When you have the vent selector on foot/defog or defog, it is the same as having the A/C button pressed in. The only difference is your A/C light is not on.
Jeff
post #11 of 13 Old 04-14-2010, 05:02 PM
Senior TN Member
Quoted: 5 Post(s)
now the question is why was there an odorless clear fluid underneath the car of the OP? where did it come from? he said he did not use the AC. maybe the OP used the heater?
post #12 of 13 Old 04-14-2010, 06:24 PM
Quoted: 3 Post(s)
Maybe it was in "floor/def" or "def" mode when this happened ??
A quick way to test is set it to "floor" and see if it drips after warm up.
My 00 Corolla worked fine by leaving it on floor, enough air flowed through the top vents to keep the windshield clear and the compressor off.
CraigW is offline
post #13 of 13 Old 04-14-2010, 10:31 PM
'10 XRS (05 & 09 XRS RIP)
rolla-XRS's Avatar
Quoted: 2 Post(s)
Possibly just condensation? Nights are cool, days warmer in Ontario (similar to OP in New York) and condensation can form.
Damn horrible dew points...always messing up my clean car and windows.
rolla-XRS is offline
  Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Corolla and Matrix Forum > Corolla 10th Gen/2nd Gen Matrix (2009-2013) > Corolla 10th Gen/2nd Gen Matrix General Discussion Forum
User Tag List
Linear Mode Linear Mode
Back
