Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1993 Corolla LE valve timing
View Single Post
Old 11-03-2006, 12:44 AM   #4 (permalink)
Ray O
Guest
Posts: n/a
View Ray O's Photo Gallery
Re: 1993 Corolla LE valve timing
"Ralph" <nospam@thanks.com> wrote in message
news:454ae23b_2@news.cybersurf.net...[color=blue]
> Thanks Ray O.
> Whatever I did put the distributor off somehow, I gather, and it is driven
> (I think) by that camshaft which is in line with the belt gear (as opposed
> to its twin shaft).
> Does the fact that the distributor was pushed off mean the camshaft is off
> too? (It was retarded, thus out by 10 degrees or more.)
> Thanks again for your comments.[/color]
If distributor timing was off by 10 degrees AND the distributor hold-down
bolt was tight, I would double-check the camshaft timing. I imagine that
the engine would barely run if one of the camshafts was off by a tooth, but
it might run well enough for the symptoms you're describing.
Ray O
