Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Timing Belt Slaps!
View Single Post
Old 11-05-2006, 07:16 AM   #13 (permalink)
kamrhee
View kamrhee's Photo Gallery
4th Generation
armrsm
After a timing belt has been placed on the pullys, crank the engine by the crank bolt clockwise with a wrench and this will remove all the slack to the tensioner. The tensioner pulley can then have some pressure applied to the belt, then tighten it down. V6 models have a spring tension sysem that tensions the belt automaticly.
Good tip. I could have use this when I was doing the belt last time. Maybe on the V6 next time.
kamrhee
1998 Camry LE 5s-fe (Stock)
2002 Toyota Highlander 1mz-fe (Stock)
My other car is a Bianchi
kamrhee is offline   Reply With Quote
