Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Backup camera for model year 2007
View Single Post
Old 11-06-2006, 08:28 PM   #14 (permalink)
pillpusher84
2011 BMW 535xi M-Sport
pillpusher84's Avatar
View pillpusher84's Photo Gallery
you will extract the pins from the CD Audio cable, and remove the wires from the pins, solder the appropriate wires from the BEC105 as i have diagrammed above, and then insert these newly soldered pins into the R10 connector in the places i have aforementioned! Be very neat with your soldering, as there is not much room in the connector, and any extra solder will prevent the pin from going into the R10 connector
as an alternative, cut the wires off of the BEC105 WHITE connector, and cut the wires from the cd audio connector. leave enough length to strip the wires & connect them to each other, solder the connection to prevent it from comming apart & cover teh connections with heat shrink tubing or simply with electrical tape!
any other questions, feel free to ask!
Current Rides:
2011 BMW 535i M-Sport xDrive (Mine), 2010 Infiniti G37S Convertible (Wife's), 2010 Toyota Rav4 Base 4cyl (Dog-mobile)
Previous Rides:
2010 Lexus RX350 AWD, 2007 Lexus GS350 AWD, 2007 Camry XLE V6, 2005 Acura TL, 2003 Nissan Maima SE, 1998 Lexus ES300
pillpusher84 is offline   Reply With Quote
