Adding Xm To Std Radio 2009 Matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 06-30-2008, 09:04 PM   #1 (permalink)
View JERRYS1234's Photo Gallery
Hoping someone can help.
I just ordered the XM receiver and XM fit kit for my 2009 Matrix with the standard radio.
Can anyone tell me how to install it; how to get the head unit out, where the Sat antenna is, and what connections I need to make?
Your help would be greatly appreciated!
Thanks,
Jerry S.
JERRYS1234 is offline   Reply With Quote
Old 07-01-2008, 11:13 AM   #2 (permalink)
View locus365's Photo Gallery
Canada
check this link out, its for a Sirius but the steps should be about the same,
http://matrixowners.com/?showtopic=76174
hope it works for you
locus365 is offline   Reply With Quote
Old 07-01-2008, 11:47 AM   #3 (permalink)
Adding Sat To 2009 Matrix
Thank you for the help. I had found that thread, but when I tried to view the pictures, it said I had to be a member. Each time I try to register, it asks for the code in the image, but all I can see is "X" where the picture of the code is. I'll keep trying to become a member of that forum.
Thanks for the help.
Jerry S.
South Florida
Old 07-01-2008, 12:47 PM   #4 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
To get the HU out, pull off the trim panel, it just pops right off, then you will need to unhook the hazard and seatbelt/airgbag light connectors. Then with the trim panel off, you will see 2 screws either side that mounts the HU. Unscrew these 4 screws and the HU will pull out.
The Sat antenna is located in the right rear cargo area behind the roof liner. There is a little blue connector that the XM kit should plug into and run the antenna wire up to wherever you mount the receiver.
As far as connections you need to make, I don't really know, I imagine you will need to connect the XM into a switched power source and a ground and then hopefully it should be a matter of plugging in whatever the kit comes with into the Head Unit.
There maybe other issues you run into, for instance I don't know if your HU has a SAT input or you might have to run it into the HU as an AUX input, or possibly use an FM switch box.
Good luck. Let us know how it goes.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.7L Tacoma 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 07-01-2008, 07:01 PM   #5 (permalink)
Thanks For The Information. I'll Let You Know How I Make Out.
Thanks Again
