2009 Matrix S 2.4L OIL FILTER!? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 08-04-2008, 10:39 AM   #1 (permalink)
View boatbuilder's Photo Gallery
Went to change the oil this weekend and the search device at the store did not have an 09 matrix in it. I asked a guy at the shop and he said PH4967 fram oil filter to use on it. So that is what I went with. This filter is considerable shorter than the Toyota Denso filter that I took off. Is this filter correct or do I need to replace it with a different one? Please advise.
Thanks!
boatbuilder is offline   Reply With Quote
Old 08-04-2008, 11:30 AM   #2 (permalink)
View toyomoho's Photo Gallery
Listed as using a PH4386.
http://www.rockauto.com/catalog/x,ca...,parttype,5340
Old 08-04-2008, 11:52 AM   #3 (permalink)
I did some more digging and found another post where it looks like Fram recently changed the filter from PH4397 to the PH4386. The 4386 is a bit longer than the 4397 but they said it won't cause any harm to the motor. I'll go with the 4386 the next time I change oil again.
THANKS!
Old 08-05-2008, 01:14 PM   #4 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
Just my 2 cents but I would have stuck with the OEM oil filter, but I understand that price and availablility come into play, in fact I used a fram on my wifes crv when I did the oil change a few months back. I'm sure you'll be fine with fram....
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.7L Tacoma 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 08-09-2008, 05:30 PM   #5 (permalink)
Neo
tucsondivots's Avatar
View tucsondivots's Photo Gallery
This is my first experience with a cannister filter. The filter (element really) box says you need an SST tool. Is that true? I tried to get my oil changed to synthetic today and my mechanic could not find a filter -- so I went and bought one at Toyota ($5 and some change).
tucsondivots is offline   Reply With Quote
Old 08-09-2008, 06:59 PM   #6 (permalink)
jdhog's Avatar
The 2.4 has a spin-on filter different to the 1.8. I replied to your post over on MO with a link to a how-to in the 10th gen corolla forum here on TN which should help.
It's just a 65mm 14 flute oil filter tool needed can get one for about $10 at most auto stores.
Old 08-18-2008, 09:38 PM   #7 (permalink)
touringcamry's Avatar
Gameroom cash: $510725
Up until recently Toyota I4s for cars (I dunno about trucks) only had two filters. The only difference is that one of them is about 3/4" longer than the other. The thread and gasket are the same size. Now there are cartridge type filters that I'm not familiar with.
In order to save money, some companies only make the smaller filter because it will fit both applications since the longer filter might not have clearance where the shorter filter is called for.
2007 Camry 2.4L 5M
Old 08-23-2008, 12:57 AM   #8 (permalink)
Owner of much Obsolete
Jeff Lange's Avatar
Gameroom cash: $383212
View Jeff Lange's Photo Gallery
The new 2.4L is the same filter as the Camry, RAV4, Highlander 4-cylinder, as well as the 2ZZ in the Celica, Matrix, Corolla XRS, and the older MR2 turbo (3S-GTE) and 4A-GE/GZE.
It's a very common filter, Toyota part number 90915-10004 or 90915-YZZF1.
Jeff
2011 Lexus IS250 Obsidian "F-Sport 6MT" with LSD
1986 AE86 Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
