I really need Hub bore of 09 Matrix - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 09-02-2008, 02:39 AM   #1 (permalink)
View krutoydiesel's Photo Gallery
i have red 09 matrix, pics up real soon, as soon as i get it fixed, im thinking of buying some 17 inch ADR, but i dunno my hub bore, and if there is too much space between hub bore and wheel bore, vibration will occur on wheels wen i drive so not good, i need to kno the hub bore so i can kno the hub centric rings i will need to buy to fill out space between hub bore and wheel bore if there is a space, please reply, i been stressing out to find this info but cant find it anywhere
Thanks,
Sega
krutoydiesel is offline   Reply With Quote
Old 09-02-2008, 01:34 PM   #2 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
I don't know the info but might be able to help point you in the right direction. First off - people are going to need to know if you have the 2.4 or the 1.8 engine - because they both have different lug patterns, and maybe hub size.
Next if you have the 1.8 - I would bet that the corolla forum might be able to help better as it is a lot busier and the corolla 1.8 will have same wheels (I think)
If you have the 2.4 engine then maybe try the Camry forums as they are the same on the Camry (I think)
Another thing if it's that hard to find the info, might be worth take a wheel off and actually measure the hub bore.
Anyway, good luck and can't wait to see your ride with some new wheels!
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.7L Tacoma 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 09-02-2008, 01:38 PM   #3 (permalink)
jdhog's Avatar
One more idea, maybe you can measure the hub bore on the spare wheel, at least you won't have to take a wheel off for that.
Old 09-02-2008, 03:19 PM   #4 (permalink)
thanks, then i might just measure the hub bore, since 2 wheels are missing anyways, thats the reason i am buying rims, i have the 1.8L engine, so if anyone knows the exact measurement of the hub bore, please tell me,
Last edited by krutoydiesel; 09-02-2008 at 03:21 PM. Reason: forgot to put my size engine
Old 09-02-2008, 08:37 PM   #5 (permalink)
2009silverbullet's Avatar
View 2009silverbullet's Photo Gallery
if you go to discounttire.com and if you pick up wheels from them they will send you centric rings with the wheel you pick out, they have a great selection to choose from, i had got my rims from there in 3 days with lugs,centric rings,balanced and mounted tires.
2009silverbullet is offline   Reply With Quote
