The only problem I have had with my 2009 Matrix S is the road noise and the "tinny" noise when shutting the doors. I put dampening material on both front doors today. Not knowing what I was doing the first door took about 1 1/2 hours and the second door about 1 hour. SIGNIFICANT improvement with interior road noise on the interstate. I plan on doing both rear door and the hatchback tomorrow. The two most known brands are DYNAMAT and DAMPLIFIER. I chose B-QUIET Extreme. It is about 1/2 the price and seems to work fine.
http://www.b-quiet.com/extreme.html
[IMG]
[/IMG]
Starting Point
[IMG]
[/IMG]
Remove panel behind door handle using small screwdriver
Use same screwdriver and pop out the power window controls.
[IMG]
[/IMG]
Remove three screws. The third is not visible and and is down in the hole behind the small tray. The two smaller visible screws do not need to be removed.
[IMG]
[/IMG]
Using panel removing tool, $10 at local auto parts store, to pop loose panel.
[IMG]
[/IMG]
Work your away around the entire panel and loosen the panel.
[IMG]
[/IMG]
Remove panel.
[IMG]
[/IMG]
Remove door handle and door lock cables.
[IMG]
[/IMG]
Slowly remove moisture barrier, be careful because this is going to be used as a template later.
[IMG]
[/IMG]
Carefully cut pieces of material and place them on the interior skin. This does not have to be an exact science. I used the left over pieces from the other door as not to waist any of the material.
[IMG]
[/IMG]
Use the moisture barrier and a template when cutting the B-Quiet material.
[IMG]
[/IMG]
This is what it looks like after cutting, rolling, and applying. You also have to copy the slit opening from the moisture barrier to allow the rods and wires through the material. Put the door cover back on and you are done!!
