Is It Just ME? - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 02-21-2009, 11:04 PM   #1 (permalink)
SportLynn's Avatar
View SportLynn's Photo Gallery
Angry Is It Just ME?
Is it just me or is anyone else having some issues with their 09' matrix?
Problem #1: my fog lights stopped working. I doubt its the bulbs because they both quit at the same time. its not the fuses, as I've checked them both. hmmmm...
Problem #2: I opened my hood today and I find that there is corrosion on the batt at the hold down and the positive terminal... WTF?
Problem #3: the pinch protection on the driverside rear window puts the window down when I shut off the car for no apparent reason at all. Not every time, but every now & again.
sooo, any ideas? anyone else or am I the lucky one?
funny enough, I Haven't had the problem with the interior door trim... yet. lol
SportLynn is offline   Reply With Quote
Old 02-21-2009, 11:44 PM   #2 (permalink)
View keyboardracer's Photo Gallery
Mild battery acid leak from terminal is not uncommon usually happen in warm environment, like temperature 20+ degrees . If severe acid build up then you might need to complain and get replace with a new one form your bumper to bumper warranty.
I am wondering did your fog light lens got cracked and water get in from your last accident 7 -8 month ago that make the light bulb burn out? usually head light/fog light bulb burn out after 2+ years.
Rear window issue, is your glass slide properly or something roll off the track? check the water strips for debits.
keyboardracer is offline   Reply With Quote
Old 02-22-2009, 09:42 AM   #3 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
Maybe the battery thing is caused a fault in the fog light circuit.
Sudden impacts maybe like the one you had a while back might have damaged the battery, or maybe you play your stereo too loud and putting extra load on the battery lol
If it isn't the fuses or bulbs it might point to a relay or short in the wiring.
I imagine a trip to the dealer would be in order or swing by autozone get them to read the OBDII and see if there's any error codes
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 02-22-2009, 05:18 PM   #4 (permalink)
Matrix Owner
View YellowVtec's Photo Gallery
Its an 09 just drop it off at the dealer tell them to fix it.
09 Matrix White 1.8L
YellowVtec is offline   Reply With Quote
Old 02-23-2009, 07:31 PM   #5 (permalink)
SportLynn's Avatar
umm.. Yeah. thanks. I got that part.
the point was to see if anyone ELSE was having issues. (either the same ones or different)
but thanks for the oh-so-helpful bump.
i have to take the car in for a service anyway. it goes in saturday.
Old 03-05-2009, 11:12 PM   #6 (permalink)
SportLynn's Avatar
ok so i took my car in for its service and i asked them to check everything out.
they said the only problem with the fog lights was the fact that the wires came uncliped..
the accident had nothing to do whith that. that was back in april last year. i started having problems in the last 2 months.
they also replace the batt. couldnt tell me why it happend tho..
the driverside window.. they just reset the operations for it.
and everything is working now, so its all good.
we just detailed the interior and exterior of the car today, a nice compound and wax.
were also starting a few painting mods.
Old 03-05-2009, 11:50 PM   #7 (permalink)
SportLynn's Avatar
Old 04-05-2009, 04:25 PM   #8 (permalink)
SportLynn's Avatar
more issues
ok, so i found one more problem we have... i got in my car the other morning ready to go to work, i let my car warm up and i go to put my windows down... only the D/S front window goes down... none of the other windows will work. its been like that for 3 days now.
anyone else?
convienence module?
Old 04-07-2009, 10:07 PM   #9 (permalink)
TRXR4KDS's Avatar
View TRXR4KDS's Photo Gallery
Window lock switch on?
TRXR4KDS is offline   Reply With Quote
Old 04-07-2009, 11:14 PM   #10 (permalink)
SportLynn's Avatar
i had checked that also. but my got in my car today and just without thinking i went to put my windows down like always. and halfway out the neighborhood i start to think about it... AND MY WINDOWS ARE DOWN!!
im thinking since it rained, something went wrong. i know there are a few cars that have that problem, not necesarally ours.
but the problem went away, they work now. but if it rains again and they dont work. ill figure on that being the cause of it, and take it to the dealer for a fix.
Old 04-13-2009, 10:48 PM   #11 (permalink)
tm1
View tm1's Photo Gallery
there's pinch protection on my electric windows?? totally didn't know that...
tm1 is offline   Reply With Quote
Old 04-14-2009, 11:35 AM   #12 (permalink)
jdhog's Avatar
I had similar thing in my old VW golf mk4 - overnight all of my windows would suddenly go down, the car was sitting outiside in freezing rain. Turned out to be a bad driver side module that was shorting out and making all the windows open.
Old 04-14-2009, 05:41 PM   #13 (permalink)
SportLynn's Avatar
yeah.. now that its dried up in the past week... they work....
