2009 Toyota Matrix/Corolla TSB - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 06-29-2009, 04:24 PM   #1 (permalink)
dchev
dchev's Avatar
View dchev's Photo Gallery
European Union 2009 Toyota Matrix/Corolla TSB
Hello guys,
I just wanted to share this info with you about TSB for our 2009 Toyota Matrix (1.8l engines).
I found this info on Corolla forum, so I will copy and paste some of info.
TSB 0087-09 - they replace gear assy. camshaft, chain tensioner and use 2 gaskets.
I went to one of local Toyota Dealers, told them about TSB, and they order the parts and install them for 2.5-3 hours. Everything was very smooth!
Just be polite and explain that you have had some noise ruttle issues when you start your engine in the morning....
Now I will copy and paste the info from Corolla forums and wish you good luck with your cars. As the mechanic told me, "it is just a mechanical problem, and I had to replace some old parts with new parts! You should not have to worry about it."
Link: TSB - Engine Knock/Rattle/Squeak on Cold Start
Just wanted to give everyone a heads up about this. My car had made a squealing/rattle sound for about a second on a cold start: I ignored it because it only happened once. For the past two days my car has done it every cold start (a total of 5 times) so I decided to take it in to the dealership. I told the tech I thought it may be the belt and/or tensioner and he agreed it was likely. I took my loaner car (downgrade to base model Corolla ) and went about my day, he assured me it should be done by early afternoon. After 4 hours I decided to call that is when I got the news that there is a TSB out for my issue and I would be without my car for 4-5 days because they do not have the parts in stock.
I had him print out the TSB information so that I could relay it to everyone here because I know others were having the same issue. The TSB does not mention a squeal but it may sound like a squeal/knock/rattle/screech/metallic grinding. Apparently this is attributed to an oil leak.
T-SB-0087-09 - March 13, 2009
Brief Engine Knock/Rattle Noise at Cold Startup
Service Category: Engine/Hybrid System
Section: Engine Mechanical
Market: USA
Applicability:
2009 Corolla - Engine(s): 2ZR. Transmission(s): 4AT, 5MT. VDS(s): BL40E, BU40E.
2009 Matrix - Drive Type(s): 2WD. Engine(s): 2ZR. Transmission(s): 4AT, 5MT. VDS(s): KU40E
Introduction:
Immediately following a cold soak startup, some 2009 model year Corolla and Matrix vehicles may exhibit a brief knock/rattle noise from the engine compartment for approximately one second. Follow the repair procedure below to address customer concerns.
Parts Information:
Previous Part Number: 13050-0T010. Current Part Number: Same. Part Name: Gear Assembly, Camshaft Timing. Qty: 1.
Previous Part Number: 11213-37020. Current Part Number: Same. Part Name: Gasket, Cylinder Head Cover. Qty: 1.
Previous Part Number: 11159-37010. Current Part Number: Same. Part Name: Gasket, Camshaft Bearing Cap Oil Hole. Qty: 2.
Previous Part Number: 13552-0T020. Current Part Number: Same. Part Name: Gasket, Timing Chain Tensioner. Qty: 1.
Warranty Information:
OP Code: EG9006. Description: R & R Camshaft Timing Gear Assembly. Time: 1.5. OFP: 13050-0T010. T1: 06. T2: 40.
Applicable Warranty:
This repair is covered under the Toyota Powertrain Warranty. This warranty is in effect for 60 months or 60,000 miles, whichever occurs first, from the vehicle's in-service date. Warranty application is limited to correction of a problem based upon a customer's specific complaint.
Well there it is, sorry for the long story to start. My car will be at the dealer until Tuesday but I will post an update once I get it back and run it for a few days. If you are having a similar issue I would take it in to be checked soon.
Market: USA
Applicability:
Introduction:
Parts Information:
dchev is offline   Reply With Quote
Old 06-29-2009, 09:52 PM   #2 (permalink)
jdhog's Avatar
View jdhog's Photo Gallery
Thanks man. Mine has been using quite a bit of oil, and I may have heard a slight rattle once or twice but was putting it down to lower oil level. Not sure, but I'll pay closer attention now.
Let me know what it's like when you get it back if you don't mind, and I may decide to take mine in.
09 Corolla Matrix 1.8l Dual VVT-i 5spd Manual Sundance Metallic - Alpine CDA 9883 - TRD drop in - Enkei BMBT 16" Alloys new addition: '93 2.4L Pickup Reg Cab 2wd
Farewell to my old Prerunner
jdhog is offline   Reply With Quote
Old 06-29-2009, 10:04 PM   #3 (permalink)
dchev
dchev's Avatar
European Union
After I did TSB, the ride is about the same for me. I will see in the next 1-2 weeks if MPG is better?....
As I said, it is worth it to do this TSB because this is covered by warranty!
As you might know, there is another TSB for oil consumption. A few months ago, I did this TSB as well. My engine does not burn any oil! However, I change my oil always! I use Mobil 1 0W20 which is maybe the best oil available on the market at the best price $5-6/bottle (on sale). I usually use 4 bottles and 4 oz. when I change the oil.
I hope this helps!
Old 06-30-2009, 09:21 AM   #4 (permalink)
jdhog's Avatar
yeah man, I change my own oil as well.....nothing to it but to do it!
I lowered my windows and turned off my stereo this morning on start-up and didn't hear any rattling or squeeling.
I don't really care too much on the TSB mainly because I'm leasing it. Not to say I don't take care of it, as I might still buy it at the end.
Thanks for the info, gald to hear yours is not using oil.
