A/c smell - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 08-20-2010, 10:29 AM   #1 (permalink)
View freedom's Photo Gallery
A/c smell
09 Matrix gets a strange a/c smell ever now and then. Anybody else have this issue? Thanks
freedom is offline   Reply With Quote
Old 08-23-2010, 10:23 AM   #2 (permalink)
Gearhead
Gameroom cash: $196215
When was the last time you check the cabin air filter? If you haven't replaced it for some time, there is a good chance that mold and mildew as well as any decomposing matter is trapped on the filter. That will eventually lead to mold and mildew growing on the inside of the condensation tray/tube - which will require a deodorizing spray down the vents to kill.
Old 09-28-2010, 11:00 AM   #3 (permalink)
View scarney1988's Photo Gallery
I agree with the above poster. In addition to checking the cabin air filter, if you can I would always recommend making sure the AC box drain tube is not clogged. Spraying compressed air up the tube ensures anything blocking it is removed. I'm sure its not clogged, but we get a handle full in each month with soaked smelly carpets because the drain tubes are not draining and it backs up onto the floor.
Good Luck
scarney1988 is offline   Reply With Quote
