Blower fan - erratic & intermittent
Matrix owners experiencing same problem?...
08 Pontiac Vibe, 48 K miles. Problem started about 3-4 months ago. With A/C on, motor cuts out and in intermittently. Needed a whack or two with a handy umbrella or something, and then it would continue on, then off, then on again with road bumps. Was okay for couple months. Acting up same way again, but now won't come on with just simple bumps -- I need to have glove box out and wrestle/muscle the black wiring harness around. Motor will run at all speeds (so not the problem I've been reading about on Vibe forum with the resistor???). However, if it's running at '3' (medium) and I move the speed control to '4' or 'high' it will cut out again. Brushes?... or wiring connector? Frustrating as this car has been on the road (only) 36 months, 48 K miles, yes this is central Fla and A/C gets used everyday, still shouldn't have to be replacing a blower fan this early. thanks, mike
