Check Engine Light - Toyota Nation Forum : Toyota Car and Truck Forums
Go Back   Toyota Nation Forum : Toyota Car and Truck Forums > Toyota Passenger and Sports Car Forums > Matrix forum > 2nd Generation (2009+)
2nd Generation (2009+) Specific discussion of the second generation Matrix
Old 01-30-2011, 12:50 PM   #1 (permalink)
View darbywolf's Photo Gallery
2nd Generation Check Engine Light
I was wondering if there is a way to manually check the engine light codes without a code reader? I know other manufacturers have an ignition sequence to check the code.
Thank you
darbywolf is offline   Reply With Quote
Old 02-04-2011, 01:23 PM   #2 (permalink)
Gearhead
Gameroom cash: $196215
Nope. For an OBD-II CAN compliant car, code reader is the only way to pull the MIL codes. The older OBD-I systems, you could read them manually, as the codes were much fewer in number and messages were more generic (ie, two digit error codes could be flashed though a lamp to be read).
