There are several out there - SprintBooster and Blitz Throttle Controller, are two that spring to mind.
Though these are just band-aid fixes, all they do it intercept the signals from the Hall-Effect sensor in the accelerator pedal assembly and adjust the modulation of the signal to the DBW solenoid. In a sense, you are amplifying the signal (pulse width control).
Swapping back to a cable actuated throttlebody will be more costly than the gains you'd receive from such a mod. Swapping to a different DBW thottle body will also not help anything, and you'll have to add a piggyback or go with a standalone EMS system to handle the difference in airflow. Gone are the days of tossing a bigger carb, now you have to please the electronic overlord as well.
The XRS reflash probably won't gain you anything, as far as I'm aware - the two drivetrains are identical between the Matrix S and Matrix XRS.
I haven't put off too much by the lag, you get used to it. Opening the throttle sooner just means more shock the drivetrain anyways - the couple of milliseconds that it response gain to your actions will easily be eaten up by wheelspin from tromping that go pedal. Though I do wish that Toyota tuned it a bit better, as their DBW implementation in their Lexus brands are superior to the Toyota branded applications.
