Originally Posted by Sundance_XR
I am still not 100% sure of the functionality of this. What exactly does it do??
They keep oil vapor from reentering the engine. The EPA has regulated that the vapor from the valve cover must be recirculated back into the air intake and vapor from the crank case must flow thru the PCV to the intake manifold.
I use to find a ton of oil at the bottom of my supercharger. Post cans, its dry.
Originally Posted by tarsun
While yes, you can get them on line, there is no internal baffling and the hose connectors are extremely small... ...the location of it.
Agreed. The cheap ones are junk. The only two I know of with internal baffling are made by Moroso and Saikou Michi.
Its important that the can has some sort of internal mesh for the vapor to condense on and that the can be mounted lower than its source so any condensation in the line drains to the can and not back to the source.
after about 60 miles today i opened it up. nothing really. though the internal filter is all oily...
My cans are about the size of a soda can each. The can on the valve cover gets to about 1/2-3/4ths full at around 5k mi. The can on the PCV is usually dry.
I have a custom built version of the Saikou Michi DC3 dual catch can with all custom positioned brass NPT fittings.
http://www.saikoumichi.com/DC3_page.htm
