Make sure the ignition is on, step on brake, depress shift button and shift into neutral - this assumes that the battery has a little bit of juice left (lights will still work).
If the battery is very weak or completely dead - the electronic shift interlock is likely giving you problems. You'll have to remove the plastic plug toward the front of the shifter plate - shove a flat head screwdriver in the exposed slot - then shift the car into neutral.
