Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Remote Start Help (Viper 160XV)
View Single Post
Old 11-09-2006, 03:26 PM   #10 (permalink)
mark01020304
mark01020304's Avatar
View mark01020304's Photo Gallery
Unhappy
Originally Posted by mazdaverx7
the best location for the antenna is going to be in the upper left corner of the windshield. inside of course. you'll only need to cut the thicker wire as its the primary. this should help a ton: this is the diagram for a remote start for the 05 camry from directsoft. this is the program i use at work when i install a remote start.
12volts
white/red (30A), white (5A)
ignition harness
Starter black/white + ignition harness Second Starter black/yellow + ignition harness Ignition black/red + ignition harness Second Ignition black/yellow + ignition harness Third Ignition N/A Accessory blue/red + ignition harness Second Accessory N/A Keysense blue - ign harn or BECU, top plug, pin 19 Power Lock blue/yellow - DKP or bottom of fusebox, 20 pin plg Power Unlock blue (double pulse) - DKP or BECU, top plug, pin 22 Lock Motor blue/red 5wi DKP or bottom of fusebox, 13 pin plg Unlock Motor blue/black 5wi DKP or BECU, bottom plug, pin 11 Parking Lights+ green + DKP or bottom of fusebox, 20 pin plg Parking Lights-
these reply is really helpful, thanx in advance. but i found that some "note" and linked document is from www.directechs.com. i had checked around, can't figure out how to access to these document. so do i have to register on it or make purchase, then i can get a login pwd?
mark01020304 is offline   Reply With Quote
