Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - ebay header
Thread: ebay header
View Single Post
Old 11-16-2006, 04:15 PM   #9 (permalink)
96_9c1
View 96_9c1's Photo Gallery
14 gauge aluminized, ceramic coated.
The header that you had listed doesnt give the kind of stainless that it is made from, so Im guess that it's not all that high on the stainless steel ladder.
Some types of stainless is more corrodable than others...
Stainless steel Grades
200 Series—austenitic chromium-nickel-manganese alloys
300 Series—austenitic chromium-nickel alloys
Type 301—highly ductile, for formed products. Also hardens rapidly during mechanical working. Good weldability. Better wear resistance and fatigue strength than 304.
Type 302—same corrosion resistance as 304, with slightly higher strength due to additional carbon.
Type 303—easier machining version of 304 via addition of sulfur and phosphorous.
Type 304—the most common grade; the classic 18/8 stainless steel.
Type 309— better temperature resistance than 304
Type 316—the second most common grade (after 304); for food and surgical stainless steel uses; Alloy addition of molybdenum prevents specific forms of corrosion. Also known as "marine grade" stainless steel due to its increased ability to resist saltwater corrosion compared to type 304. SS316 is often used for building nuclear reprocessing plants.
Type 321— superior weldability due to addition of titanium
400 Series—ferritic and martensitic chromium alloys
Type 408—heat-resistant; poor corrosion resistance; 11% chromium, 8% nickel.
Type 409—cheapest type; used for automobile exhausts; ferritic (iron/chromium only).
Type 410—martensitic (high-strength iron/chromium). Wear resistant, but less corrosion resistant.
Type 416— easy to machine due to additional sulfur
Type 420—"Cutlery Grade" martensitic; similar to the Brearley's original "rustless steel". Also known as "surgical steel". Excellent polishability.
Type 430—decorative, e.g., for automotive trim; ferritic. Good formability, but with reduced temperature and corrosion resistance.
Type 440—a higher grade of cutlery steel, with more carbon in it, which allows for much better edge retention when the steel is heat treated properly. It can be hardened to Rockwell 58 hardness, making it one of the hardest stainless steels. Also known as "razor blade steel". Available in three grades 440A, 440B, 440C (more common) and 440F (free machinable).
500 Series—heat resisting chromium alloys
600 Series—martensitic precipitation hardening alloys
Type 630—most common PH stainless, better known as 17-4; 17% chromium, 4% nickel
Im not saying that header is a bad header, just that wrapping it will over time cause it to become brittle.
Ask the Ebay seller if he will warrenty they header if its wrapped...
96_9c1 is offline   Reply With Quote
