Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 1991 Previa Instrument Gauge lights gone
View Single Post
Old 11-18-2006, 04:37 PM   #11 (permalink)
Jeff Strickland
Guest
Posts: n/a
View Jeff Strickland's Photo Gallery
Re: 1991 Previa Instrument Gauge lights gone
I'd be looking to the mods as the source of the problems. Since the stuff
you DID NOT modify is still working properly, my guess is that the stuff you
did modify has failed.
"Matty" <mattguillory@gmail.com> wrote in message
news:1163885773.675749.89170@m7g2000cwm.googlegroups.com...[color=blue]
> Sorry Jeff, I should have been more specific.
> As of now, ONLY the speedo cluster lights are not working. The A/C
> climate control lights are working just fine and are still adjustable
> with the dimmer dial. Tail lights are working fine.
> Here are some recent mods I have done with the previa:
> 1) Installed an aftermarket stereo/dvd and satellite radio receiver
> about a week and a half ago (Which is working just fine)
> 2) Replaced 4 speedo 194-gauge bulbs with 194-gauge LEDs about 3 weeks
> ago.
> Everything was working like a charm up until 2 nights ago.
> -Matty
> Jeff Strickland wrote:[color=green]
>> That would have been good to tell us earlier. ;-)
>> So, SOME of the instrument panel lights come on and can be controlled by
>> the
>> dimmer?
>> news:1163884739.059803.42610@m7g2000cwm.googlegroups.com...[color=darkred]
>> > The A/C climate control lights still work and the dimmer can still
>> > control those. Does that still mean that the dimmer control needs to be
>> > replaced?
>> > Thanks,
>> > Matty
>> >> My vote is that the dimmer has failed.
>> >> news:1163883579.527459.95580@e3g2000cwe.googlegroups.com...
>> >> > Hi Jeff,
>> >> > Thanks for the quick reply.
>> >> > The tail lights are fully functional. That was actually the first
>> >> > thing
>> >> > I checked. And the dimmer dial is set to maximum brightness. I am
>> >> > totally confused.
>> >> > This problem really has me scratching my head.
>> >> > -Matty
>> >> >> One
>> >> >> Check to see if the tail lamps are working or not. The tail lamps
>> >> >> and
>> >> >> the
>> >> >> instrument panel lights share the same fuse. If the tail lamps are
>> >> >> not
>> >> >> on,
>> >> >> then you haven't found the correct fuse yet.
>> >> >> Two
>> >> >> There is a knob that adjusts the brighness of the instrument panel
>> >> >> lamps.
>> >> >> Have you checked the knob to see if it is adjusted to the correct
>> >> >> position -- basically any position that is not Full Off.
>> >> >> news:1163882159.472049.68080@k70g2000cwa.googlegroups.com...
>> >> >> > Just the other night, I hopped in the Previa to run an errand and
>> >> >> > when
>> >> >> > I went to turn the headlights on, NONE of the speedmeter lights
>> >> >> > worked
>> >> >> > including temp and gas. Fuse seems to be okay. Any ideas about
>> >> >> > what
>> >> >> > the
>> >> >> > problem could be?
>> >> >> > This is really bugging me.
>> >> >> > Thanks,
>> >> >> > Matty
>> >[/color][/color]
>[/color]
