Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Corolla Axle Shaft Seal Replacement
View Single Post
Old 11-19-2006, 11:55 PM   #5 (permalink)
Weldman
Guest
Posts: n/a
View Weldman's Photo Gallery
Re: Corolla Axle Shaft Seal Replacement
Thanks, Ray. Do you know what size the hub nut should be? I think I
have a 27, 32, and 36mm sizes.
Ray O wrote:[color=blue]
> "Weldman" <wrenwright@gmail.com> wrote in message
> news:1163986169.937451.227000@h48g2000cwc.googlegroups.com...[color=green]
> > I'm helping a buddy out with a leak on his automatic-equipted '93
> > Corrola.
> > It is leaking trans. fluid from around the drivers side axle seal.
> > I've done this job on Hondas, but never on a Toyota.[/color]
> One big difference between Hondas and Toyotas is that the front of the
> engine faces the RH side of the car ;-)
>[color=green]
> > How does one get the seal out of the transmission? Is there a circlip,
> > or?[/color]
> I am pretty sure that there is a C-clip that holds the driveshaft but the
> seal should just pull out. Besdes replacing the seal, you will have to
> replace the dust seal at the hub and the C-clip.
>[color=green]
> > Anything else I should know abou this job?
> > Thanks.
> >[/color]
> Ray O
> (correct punctuation to reply)[/color]
