Originally Posted by ghettosled
just for reference sake, my 96 camry doesnt need shims to clear the cover. are you sure the cover is on tight? if you shim the PS pulley too much, it will wear the belt quicker with the 2 pulleys not being aligned.
I haven't had the opportunity to try to take the cover back off yet, but when the engine was out, I tried to see if it had any give to it, and it didn't seem to. Could anything be obstructing it from behind that I'm not thinking of?
Yeah, the pulleys being out of alignment was my biggest worry if I considered shimming it. It's just weird how the bottom has a little bit of a gap, almost like the pump is not quite parallel or something, i dunno...
