Anyone know what the CFM of the MAP air intake is??
https://en.wikipedia.org/wiki/Mass_flow_sensor said:A mass (air) flow sensor (MAF) is used to find out the mass flowrate of air entering a fuel-injected internal combustion engine.
The air mass information is necessary for the engine control unit (ECU) to balance and deliver the correct fuel mass to the engine. Air changes its density as it expands and contracts with temperature and pressure. In automotive applications, air density varies with the ambient temperature, altitude and the use of forced induction, which means that mass flow sensors are more appropriate than volumetric flow sensors for determining the quantity of intake air in each cylinder. (See stoichiometry and ideal gas law.)
https://en.wikipedia.org/wiki/MAP_sensor said:he manifold absolute pressure sensor (MAP sensor) is one of the sensors used in an internal combustion engine's electronic control system.
Engines that use a MAP sensor are typically fuel injected. The manifold absolute pressure sensor provides instantaneous manifold pressure information to the engine's electronic control unit (ECU). The data is used to calculate air density and determine the engine's air mass flow rate, which in turn determines the required fuel metering for optimum combustion (see stoichiometry) and influence the advance or retard of ignition timing. A fuel-injected engine may alternately use a mass airflow sensor (MAF sensor) to detect the intake airflow. A typical naturally aspirated engine configuration employs one or the other, whereas forced induction engines typically use both; a MAF sensor on the intake tract pre-turbo and a MAP sensor on the charge pipe leading to the throttle body.
