Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 92 Truck Wont Idle
View Single Post
Old 06-05-2003, 12:13 PM   #14 (permalink)
sball
View sball's Photo Gallery
Mounted on the top of the drver side front fender well is a small black box. If I am not mistaken part of the name is igniter assembly. A wire runs from this to the distributor. This wire is in an insulated shroud that contains two wires inside a steel braid sleeve all contained in the shroud. The braided sleeve exits at the igniter and connects to a screw as though a ground. The confusing part of this is that at the other end (distributor end) the braid does not come out of the insulation and apparently does not connect anywhere for that end is sealed with only two wires connecteing to the distributor.
sball is offline
