Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Are you a Scion Owner?'
View Single Post
Old 11-27-2006, 07:24 PM   #5 (permalink)
=?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?=
Guest
Posts: n/a
View =?iso-2022-jp?q?Hachiroku_=1B$B%O%A%m%=2F=1B=28B?='s Photo Gallery
Re: Are you a Scion Owner?'
On Mon, 27 Nov 2006 08:39:18 -0700, CMM wrote:
[color=blue]
> On Thu, 23 Nov 2006 01:06:10 GMT, Hachiroku ???? <Trueno@AE86.gts>
> wrote:
>[color=green]
>>On Wed, 22 Nov 2006 14:45:14 -0700, CMM wrote:
>>[color=darkred]
>>> On Tue, 21 Nov 2006 19:24:03 GMT, "Hachiroku" <Trueno@ae86.GTS> wrote:
>>>>Do you have a Manual Transmission, and a Throttle-by-wire system?
>>>>Are you tired of that slight hesitation that can send your car into fits
>>>>like a Bucking Bronco if you don't time the Clutch and the Gas *Just Right*?
>>> Wow, never noticed any problem. Any manual car has a hard time if you
>>> don't know how to work the clutch and gas pedal right.[/color]
>>Well, ya know, I've only been doing it for, oh...thirty-two years now.
>>Never had this problem with my 'hachiroku' (not available with A/T).
>>258,000 miles on the original clutch.
>>Or my '80 SR5...247,000 miles, original clutch.
>>Or my '74 Corolla...first car I ever owned, NEW and had never driven a
>>4-speed before. Gee, come to think of it, I had never driven ANYTHING
>>before...125,000 and then sold the car. With the original clutch.
>>...I think maybe I know what I'm doing...and I don't have to smoke
>>clutches to prove it, either.
>>Come to think of it, the only transmission problem I have ever had is with
>>my Supra...ya know, the one with the Automatic.[/color]
> I wasn't doubting your experience with clutch usage. I've just never
> had a problem with my Scion. What year and model are you driving?
> -- Christian[/color]
Oh...sorry Chris...I thought you were being a wise @ss!
I have an '05 tC. If you look at [url]www.scionlife.com[/url], it seems there is an
issue with the drive-by-wire system introducing a slight hesitation when
you initially depress the gas pedal. One guy who's an engineer (and who's
experieince is quite surprisingly similar to mine-Electronics, Avaition
and Avionics and computers) thinks this is caused by the automatic
'calibration' of the throttle potentiometer by the ECU. I had figured, if
there was an adjustment for the pot, then the hesitation could be
overcome. He did too, and tried it, and the ECU compensated for it,
and...hesitation.
Like I said, I've been driving 4 and 5 speeds for over 30 years, and with
two of them I was SO smooth it was like driving a car with a CVT!! But the
tC threw me, I didn't know what it was. But, by the extremely light
feeling of the throttle, I figured it must be a d-b-w system, and then
discovered I was correct.
So, in implementing the 'fix' from Scionlife (get rubber 'feet' and place
them where the throttle linkage 'rests' against the stop) I found this
set-screw type deal. It seems to have stopped the hesitation and I can
shift now more like I'm used to!
One of the guys (the engineer, I believe) even added another spring to the
trhottle to make if feel more like a cable type linkage and provide a
little more 'feedback', something I notice is missing. I can hold my Supra
rock-steady on any raod at any speed, but with the tC I have to keep an
eye on the speedo! (But then, my Corolla GTS is a lot like this,
too...it'll get you going faster than you think you should be very easily...)
What type of Scion do you have? And, have you been to Scionlife yet?
Next task...swap the Orange LEDs in the dash for blue...!!
Also, have you found how to change the radio 'equalizer' yet?
