Transmission Fluid Refill
Hi everyone,
I have been asking many questions regarding my 98 avalon that I recently purchased. I love the car and I am a fanatic on servicing my vehicle. I read one of the threads about the amount of fluid that will drain upon removal of the transmission drain plug. I believe 4 to 5 quarts was mentioned. I only drained a little over 2 quarts from my transmission. I added two back which I will drain again before I drop the pan to help flush out some of the old fluid. When I checked the level after adding the 2 quarts it appeared to be overfilled or I could not get a good reading after I warmed up the transmission. What do you think.
I really do appreciate hearing from all of you with your help and suggestions. I want to learn all that I can about my Avalon.
Thanks,
Mark
