2006 Avalon catalytic converter smell - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-27-2005, 04:31 PM   #1 (permalink)
View acoldstarnolds7's Photo Gallery
When I accelerate quickly on my 06 I get the sulfer smell inside the car. This is with the windows closed and the a/c on fresh air. Should'nt all that odor exit out the tailpipes?
Does this indicate an exhaust leak under the hood?
acoldstarnolds7 is offline   Reply With Quote
Old 12-27-2005, 05:34 PM   #2 (permalink)
View 05Limited's Photo Gallery
Could be a damaged converter. If they are working right and doing their job there should be no sulfer smell.
05Limited is offline   Reply With Quote
Old 12-29-2005, 01:26 PM   #3 (permalink)
View jimmykce1's Photo Gallery
What octane gas have you been using?? If you use a lower octane than the required 91+, you could of damaged the cat.
jimmykce1 is offline   Reply With Quote
Old 12-29-2005, 04:53 PM   #4 (permalink)
The required octane is 87 or better. It is stated you may get better perforamance, i.e. more horsepower, from a higher octane but 87 is all that is required.
Old 12-29-2005, 09:30 PM   #5 (permalink)
I appreciate the responses but please consider my original question. I am smelling this through the a/c vents. The exhaust should all be out the pipes and the back of the car.
Is this an exhaust leak if I am smelling this in the cab as soon as I accelerate? How would the smell get in the a/c vents unless there was an exhaust leak?
Old 12-30-2005, 07:14 AM   #6 (permalink)
IF your smelling it through the vents than it may be an exhaust leak by your exhaust manafold or midpipe connection. I would take it in to the dealer since its still under warranty.
Old 05-05-2006, 11:14 AM   #7 (permalink)
View kwirnu's Photo Gallery
there is a tsb concerning the excessive sulfur smell. If the dealer doesn't replace a catalytic converter then call toyota headquarters and tell them what your problem is and that you want a new catalytic converter as the solution to the problem as required by the tsb.
kwirnu is offline   Reply With Quote
