97 Avalon leading valve cover gaskets - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2006, 08:35 PM   #1 (permalink)
View fasterblaster's Photo Gallery
Youch. Just got notice from the dealer that my 97 Av has oil leaking from the valve covers. Didn't seem like a big deal to me. Put new ones on I say. Its a $100 for the parts and 5 hours labour ~$500.??????? What the.... I says.
I am thinking 1/2 hour each side. I have fixed lots of parts on lots of my cars over the years. Is this beyond the Sunday mechanic or is this one of those prescribed "book" costs when it can be done in 1-1.5 hours?
Any advice would be appreciated. Also does anybody know the torque spec for the valve cover bolts?
FB
fasterblaster is offline   Reply With Quote
Old 01-28-2006, 09:49 PM   #2 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $281092
View csaxon's Photo Gallery
How bad is the leak? It might just need snugging the bolts up a bit.
It's easy to do but time consuming taking everything off and putting it back on.
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-29-2006, 03:45 PM   #3 (permalink)
I was wondering about that.
Does anybody know the torque specs for the valve covers?
Old 01-29-2006, 04:41 PM   #4 (permalink)
Torque 8Nm, 80 kgf cm, 69 inch lbf.
Old 01-29-2006, 08:31 PM   #5 (permalink)
View sloopercat's Photo Gallery
Those bolts are also designed to breakaway if overtorqued. They did that to save breaking the head. So you will need to use the correct torque wrench. Your lucky you drive an Avalon instead of a Camry, if you decide to do that job yourself there is a lot more room to work on than a Camry. It is not a challenging job, just a lot of stuff to remove to get at the back cover. 5 hours flat rate, I am sure a decent mechanic can do it in 3 or less. You might ask around, discreetly of course, and see if any of the mechanics at the stealership moonlight.
sloopercat is offline   Reply With Quote
97 Avalon Valve Cover Gasket hdt98 1st Generation (1995-1999) 4 11-08-2004 09:44 AM
Taking off the Valve Cover Piddy MR2 Forum 4 08-19-2004 11:53 AM
Remove 3s-fe valve cover jay_wang2000 Camry & Solara Lounge 6 02-14-2004 12:02 AM
97 camry rear speaker cover CaNtKnEzGuy 3rd & 4th Generation (1992–1996 & 1997–2001) 5 11-16-2003 03:06 AM
97 Avalon Buttz General Discussion 2 10-04-2002 01:56 AM
