Hi
Take a look at the post a few down the page. A guy there appears to have had the same problem, changed PS and R&P and still had a problem. He then changed the "steering knuckle" which connects the steering shaft to the R&Pinion whcih seems to have solved the problem
If the level has never gotten low I can't see why the R&P should be worn out, it should be just a leakage issue, The knuckle makes the most sence. PS maybe if there is a noise when turning the steering wheel, can't see the R&P making any noise.
I have had this stiff steering problem on two 99's, the first one started at 110K sold the car at 125k and bought a Platinum 99 with 68K. It now has started the same intermitant stiffness at 75k. There have been no leaks and didn't added fluid on either car.
Any comments from the more knowledgable.
Brian
