1996 Avalon Engine Light ON?! HELP~ - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2003, 02:11 AM   #1 (permalink)
View Hybrid-JD's Photo Gallery
i currently own a 96 toyota avalon xls. its been great so far but the engine light has been on for the past couple months. i've brought it to the dealership and they've reset the sensor and what not but it still comes back. they've told me many times that its nothing but it seems to come back. FINALLY this time when i went back they told me that its my "Knock 2" sensor. Price of it was like 180 and install was another 400 Canadian. i said not i would wait for abit.
anyonw konw whats the down fall with the KNOCK 2 sensor?
anyone else have the same problem?
btw. i've also noticed after having the engine light on.i've noticed my gears haven't been changing properly. or when it does change. it seems to be very rough.. it goes to gear 4 sometimes ..but when sometimes i floor the pedal it does nothign but sit at ilke 3thousand and it just goes really slow?
HELP PLEASE!
thanks
Jimmy
1996 Toyota Avalon XLS
"Get Lifted" Fridays @ Pearl Lounge
Featuring: $3.50 Drinks ALL NIGHT LONG!
240 Richmond St. West.
www.hybrid247.com
For Info/Guestlist: 416.404.8233
Hybrid-JD is offline   Reply With Quote
Old 01-30-2003, 11:15 AM   #2 (permalink)
View STR8PYP's Photo Gallery
If it's a knock sensor that's busted you should get it replaced. The ECU will pull back timing and you will experience extreme power loss until you do so.
SC
http://www.schung07.com/
http://www.thewheelsupply.com/
STR8PYP is offline   Reply With Quote
Old 01-30-2003, 02:29 PM   #3 (permalink)
NO wonder i'm loosing power!! Do you konw what the knock sensor does? and also, do you konw what would be a reasonable price to get it fixed!?
hmm thanks alot for the alert. are yu located in Toronto? has this ever happened to you before?
thanks
Jimmy
SC
www.hybrid247.com
Old 01-30-2003, 02:53 PM   #4 (permalink)
it was all a dream
Thanked 4,294,967,295 Times in 4,294,967,294 Posts
View Ratko's Photo Gallery
the knock sensors (you have 2) are there to detect knock in your engine caused by detonation, which will kill your engine over time. since this is bad, when the sensors detects knock, it retards your timing slightly to compensate for the knock (or pinging).
btw - im located in toronto
ratko.org
Ratko is offline   Reply With Quote
Old 01-30-2003, 04:47 PM   #5 (permalink)
is this a known issue to alot of 1mjze engines? or is this a rare instance that only happens to a few.. i'm also hearing something about "sludge" can anyone give me a basic definition of that.
Hey Ratko. would you konw anywhere in Toronto where you could reccomend me to fix this problem for a reasonable price. "Downtown Toyota" quoted me 600 plus to fix it.
thanks
Jimmy
www.hybrid247.com
