'97 Avalon Rear Control Arm Bushings Went Bad!!!
After spending almost $1000 to get a new rack and pinion, CV axle, and steering knuckle installed, I find out the rear control arm bushings are worn out! After the work I had to take it to be aligned and the tech showed me how loose they were. In the near future I will have to replace them. My questions is, can you buy just the bushings, or do you need to replace the whole arm? The arms that went bad were the ones where you make the adjustments for the alignment. Thanks in advance.
